thrust bearing installation
  • wavekatcher
    • Jul 2012
    • 38
    What is the proper technique for installing the thrust bearing? I noticed the shaft on the motor has some in/out play. Do I find the half way point of this play then install the collet up against the thrust bearing?
    I have it installed already. What I did is, pulled the shaft to the aft position then tightened the collet down against the thrust bearing.
    Revolt 30, SuperMonoX, NQD "Tear Into"
  • dana
    Banned
    • Mar 2010
    • 3573
    Not really the best way. The motors bearings are designed to take thrust, so IMO thrust bearings aren't necessary, but if I were using one I would just install it without trying to get rid of play.
    • stumblinh
      • Jul 2012
      • 52
      Install the bearing in the normal rested position, you don't want the wear from being "in the middle" with constant drag and load. Not effecient.
      • gyrotron
        • Jul 2012
        • 481
        Stum,
        If you have one of these installed in your boat, can you show us some pics?
        Thx
        • wavekatcher
          • Jul 2012
          • 38
          Forgive my stupidity, What is normal rested position of the shaft? Run the motor without anything attached, then connect?
          • Mike Caruso
            • May 2012
            • 940
            Before the boat ever was in the water, I was running my motor out of the boat and it made a small amount of temp. I thought that's crazy! I order the bearing I installed it in the middle of the end play. Ran the motor the same way as before out of the boat PRESTO NO TEMP build up. Time will tell but this leaves the motor bearings to just take care of rpm and not the thrust. Comes under the heading of too much time on my hands.
            Do It Like You Mean It .....or Don't Bother
            • Basstronics
              • Jun 2008
              • 2345
              Originally posted by dana
              Not really the best way. The motors bearings are designed to take thrust, so IMO they're useless, but if I were using one I would just install it without trying to get rid of play.
              Radial ball bearings were never designed to take thrust.
              • dana
                Banned
                • Mar 2010
                • 3573
                Edit. You can take my advise on the bearing thing. They will take thrust. Thanks jay
                • wavekatcher
                  • Jul 2012
                  • 38
                  So, exactly where does the thrust bearing go? I still am unclear. Btwn the drivedog and prop??
                  • dana
                    Banned
                    • Mar 2010
                    • 3573
                    Between the collet and motor mount plate/motor can
                    • domwilson
                      Moderator
                      • 4408
                      Here is a pic of how mine is installed in one of my boats....
                      Government Moto:
                      • wavekatcher
                        • Jul 2012
                        • 38
                        Thanks everyone. Looks like I did the install correctly.
                        • domwilson
                          Moderator
                          • 4408
                          Make sure you pack the bearing with plenty of grease.
                          Government Moto:
                            • 8012
                            Wow, lots of bad information in this thread....
                            Not so. Many of the motors we use are designed for airplanes with the prop directly attached to the motor shaft. They are not only designed to take thrust, they do it very well.
                            All electric motors build heat when run without a load because virtually all the energy goes into heat, not torque. The thrust bearing had nothing to do with heat buildup in the motor.
                            A thrust bearing does nothing if it does not transfer thrust from the prop to the hull. It does this ONLY if the bearing is pinched between the coupler and the motor under forward movement - otherwise the motor's endbell bearing is transferring all the thrust (usually not a bad thing at all). When set up correctly a thrust bearing will not be loaded when the motor isn't running, otherwise it will cause unwanted friction. If a motor shaft has axial run out - end play - measure the play and install the thrust bearing so that only half the end play remains. This will insure two things - that the bearing is actually taking thrust when the boat is moving, and that the thrust bearing is not adding friction by pinching the PTO bearing between the internal shims and the thrust bearing/coupler.
                            Many small bearings are not meant to be "packed with grease". Most will sling out any grease as soon as the motor spools up. You need to use a bearing oil that will stick to the races and balls for the few minutes the motor runs. What you have to remember is to re-lube the bearing after every use and don't let it rust.....
                            • wavekatcher
                              • Jul 2012
                              • 38
                              Thanks for the clarification Fluid. Are you sure the bearing doesn't go btwn the drive dog and prop?
