My Eagle Tree data with m445
  • detox
    • Jun 2008
    • 2310
    Be carefull...my detunged x645 killed my ESC.
    • LuckyDuc
      Team Ducati Racing
      • Dec 2008
      • 989
      If it cooks the ESC then others will know not to try it
      I've been looking at a Hydra 120 anyway
      • Capt. Crash
        • Jan 2009
        • 301
        52mph...congrats....that is way cool! What was your prop setting?
        • LuckyDuc
          Team Ducati Racing
          • Dec 2008
          • 989
          The strut is at 1" and the prop is angled down at 2 degrees. Batteries are all the way forward.
            • 9479
            Ok, I think I know what the 1" at the strut means, but what or how do you get the 2* prop angle?
            • detox
              • Jun 2008
              • 2310
              Lowering the strut will usaully put the needed angle on the strut. Using a setup board you should see light under the front edge of strut. 030" clearance will work. Some have used more in the UL1 with good results . You just have to test
                • 9479
                Does lowering the strut loosen the boat up?
                • LuckyDuc
                  Team Ducati Racing
                  • Dec 2008
                  • 989
                  #23
                  Lowering the strut helps stabilize the boat by lowering the nose of the boat. If it is running too wet then raise it a tad.
                    • 9479
                    #24
                    Here is the last chart I'm doing with the m445 before switching to a Grim L40x57 for testing. Hit 52mph in the straights.
                    Check out Temp B. That is the ESC's Deans Connector!
                    Does your cool Eagle show RPM ?
                    • LuckyDuc
                      Team Ducati Racing
                      • Dec 2008
                      • 989
                      #25
                      It can, but I don't have that sensor. I have the two temp sensors and the GPS expander.
                      I could give you a chart with voltage and you could estimate RPM using math.
                      Motor KV (2030) x voltage = RPMs
                        • 9479
                        #26
                        But under a load would be different...
                        • LuckyDuc
                          Team Ducati Racing
                          • Dec 2008
                          • 989
                          #27
                          It wouldn't be as far off as you think because voltage drops as well when load is applied.
                          • detox
                            • Jun 2008
                            • 2310
                            #28
                            I hope your newly sharpened L40 X 57 prop goes faster. Please post Eagle Tree numbers and speed afterwards.
                              • 9479
                              #29
                              Yes voltage does drop under load, but you cannot just multiply volts (4s) times kv to get your top rpm under a load...
                              I have a 60 size Cap 232 with a 500kv motor.. On 6s it will spin well over 11k free, but with a 16x8 prop my rpm is around 8k..
                              So by your math I'm only at 16v but in reality my batteries only drop about 1.5v..
                              • LuckyDuc
                                Team Ducati Racing
                                • Dec 2008
                                • 989
                                #30
                                Will do. The weather has been cruddy for the last couple of days.
