Got a UL-1...let's see it!
  • sailr
    • Nov 2007
    • 6927
    #121
    Nice paint job! I like it!!
    Mini Cat Racing USA
    www.minicatracingusa.com
    • jingalls007
      • 1015
      #122
      Originally posted by bigpapa
      latest addition
      nice paint!!!! looks fantastic!!
      • jingalls007
        • 1015
        #123
        How about a vid...
        http://www.youtube.com/watch?v=OSOzWkoAYU8
        has anyone tried the L38x55 prop?
        yes to the 38X55 grim prop, I liked it but not as much as the M440. my favorite thus far (and wayyyy tooo much prop for the stock ESC and motor) is the X645. don't try it but that was a beast in the boat, my UL-1 just about popped a wheelie across the water, it was cool.
        • bigpapa
          • Apr 2009
          • 2330
          #124
          awsome video footage
          • Capt. Crash
            • Jan 2009
            • 301
            #125
            Some one in my club had one on his boat this weekend and that boat was glued to the water. He said it ran around 41mph. Here is a pic I took of it.
            I read somewhere that the M440 is the same pitch/diameter as the Grim 40X52/3. I only got lower/mid 40s with the 40X52....but my boat was glued to the water.
              • 9488
              #126
              Ok, not sure if I should buy a L38x55, an M440, or40x52/3 ?
              the vid I posted was with a S220
              • sewerpit
                • 117
                #127
                tried the m440 this weekend got 42.4 on gps boat was glued to the water on turns it was on rails strut set at 1 1/8th, turn fin slightly up , 2 4900 25c lipos, i think i need to tweek rudder a bit boat ran awsome very impressive temps motor esp and batts all around 100 ran for about 3min
                • detox
                  • Jun 2008
                  • 2318
                  #128
                  Buy all three then test to see wich one you like best. In perfect water my UL-1 reached 50mph using the m440 and the L40 x 57/3. I have not tested the L38 x 55 prop enough but it seems fast also. Flightpower 2s 25c 4900mah and Hyperion G3 2s 25c 5000mah lipo packs were used during all testing.
                    • 9488
                    #129
                    were your temps different between the two props?
                    • detox
                      • Jun 2008
                      • 2318
                      #130
                      These are the only temps I remember using the m440...motor temp 119, esc 93, Q3 batteries 115
                      The L40 x 57/3 temps were similar...or not high enough to worry with.
                        • 9488
                        #131
                        So about the same between the two..
                        good info, thanks
                        I have worked on my S220 a little more and will let it rip tomorrow on the water and see if I get more speed.
                        • detox
                          • Jun 2008
                          • 2318
                          #132
                          Water conditions play a big role in top speed. UL-l is very stable and fast in smooth slightly choppy water, but larger chop and race water will slow it down noticeably and make it more LOOSE. Playing with a more forward COG may correct this problem. I have two heavier 4s 35c 3300mah that I will mount sideways in front of hull. This may correct the looseness in choppy race water. Or adding lead may help also.
                            • 9488
                            #133
                            I think my UL-1 is a little faster in small chop
                            • jingalls007
                              • 1015
                              #134
                              i liked the M440 but after testing the 38x55 a bit more, i noticed more speed overall and quicker acceleration out of the turns. 38x55 ran hotter then the M440 as well.
                              • detox
                                • Jun 2008
                                • 2318
                                #135
                                Thanks for the info. I will have to try the 38 x 55 again.
