Got a UL-1...let's see it!
  • bustitup
    • Aug 2008
    • 3071
    #91
    LoL....at least u didn't HIT the buoy like the guy in the little rigger......it ma
    de a loud pop and he sat there broken and dead in the water
    • sailr
      • Nov 2007
      • 6927
      #92
      I nailed a buoy on saturday during practice and destroyed the nose cowl! That's why my boat looked so funny out there on Saturday! I think Mike got his rigger repaired later. I had a piece of brass tubing with me that got him back going I hope!
      Mini Cat Racing USA
      www.minicatracingusa.com
      • SHOWBOAT1
        • 3
        #93
        hey, i saw the post and thought id show my boat ,i have never ran it yet,because i had to fix the hull at the turn fin because http://forums.offshoreelectrics.com/...&pictureid=448 it was broken when it arrived i fixed using Darins methed to repair, hope to run it soon.
        • sailr
          • Nov 2007
          • 6927
          #94
          Nice! I like the rivets!
          Originally posted by SHOWBOAT1
          hey, i saw the post and thought id show my boat ,i have never ran it yet,because i had to fix the hull at the turn fin because it was broken when it arrived i fixed using Darins methed to repair, hope to run it soon.
          Mini Cat Racing USA
          • sewerpit
            • 117
            #95
            plain and simple looks sharp nice boat
            • Capt. Crash
              • Jan 2009
              • 301
              #96
              Cool Beans!
              • longballlumber
                • 3132
                #97
                My UL-1
                This is mine... I did open up the bottom of the hull and did some work in the turn fin area to get some strength and structure in there. I also did alot of work on the sponson ride pads. I shimmed and sheeted the right sponson so that it had 1 degree of dihedrial. I shimmed and sheeted the left sponson so that is was completely flat. I finished shooting color on Monday. I will start putting it back together later this week.
                Mike
                • sailr
                  • Nov 2007
                  • 6927
                  #98
                  What is the theory of giving the right sponson 1 degree of dihedral?
                  Mike
                  Mini Cat Racing USA
                  • Darin Jordan
                    • 8335
                    #99
                    If you look at most of the fast riggers, you'll find that the outside sponson is flat, and the inside is about 1-degree.... I believe they do this to promote better tracking and to counter prop torque. I think it causes one of the sponsons to have a tad more drag, which offsets the prop torque and helps the boat track straighter.
                    I like the upgrades... similiar to the ride-pads I added on mine, which put the sponsons at just about the same angles... I think mine is more like 0.5 degrees on the left and 1.5 on th right...
                    Based on the reports of sponsons walking with these boats, I might be inclined to increase the angles a tad more to see if that could be overcome, but I'd replace or properely tune the turn fin first. Many of the pictures I've seen show the boat riding on the bottom of the turn fin. If the boat is fighting that hook in the bottom of the fin, that'll cause issues... Maybe throw a straight fin on there to get everything else dialed, then start playing with the hook. I've personally never had good luck with hooked fins... and always just use a straight one with about 5-10 degrees of inward angle...
                    Darin E. Jordan - Renton, WA
                    • longballlumber
                      • 3132
                      #100
                      Maybe throw a straight fin on there to get everything else dialed, then start playing with the hook....
                      That is a good idea Darin. I may give that a try.
                      Mike
                      • longballlumber
                        • 3132
                        #101
                        Darin alreay answered in detail. I was told that the flat and the 1 deg was the intention of the design. However, my hull had anhedrial angle on both sponsons. So, I went thru the process of making it right. As for the angles themselves, everyone has there ideas. Actually on Brian Blazer's 20 Whiplash it's the opposite. Flat right side and 1 degree dihedrial on the left. To each their own.
                        Mike
                        • properchopper
                          rcgoatbuild@snotmail.com
                          • 6968
                          #102
                          fin
                          This works for me. Fuller's fin, basically bolts right on with one hole to drill.
                          • SHOWBOAT1
                            • 3
                            #103
                            I ran the UL-1 yesterday and i must thank GRIM and Aquacraft for coming
                            up with an rtr that isnt a complete turd! It was very fast and easy to control
                            i have a lot of set up questions but overall its the best hydro ive ran,
                            • H2OCamel
                              FAST ELECTRIC EVERYTHING
                              • Oct 2007
                              • 484
                              #104
                              Shoboat nice paint! The rivits are very cool!
                              "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
                              • sailr
                                • Nov 2007
                                • 6927
                                #105
                                It absolutely is a great running and driving RTR! I hope they will upgrade the quality of the construction of the hull soon. I will buy another one if they do! Problem is, I don't know if AQ will tell us when they do it!
                                i have a lot of set up questiopns but overall its the best hydro ive ran,
                                Mini Cat Racing USA
