How To Stop Sponson Walking
  • TLeyde
    • Aug 2011
    • 88
    Originally posted by photohoward1
    Give it up. That's what UL1's do when they hit that speed. No prop on earth will fix it.
    I'm a nitro guy getting into some FE. Looks like I'll just get the PT Stealth all rigged to go then. I was unaware of this never had these issues with my PT SP 21 nitro.
    TL
    • mtbenjamin77
      • 761
      TL
      you might be able to get it to settle some with a high lift prop. Octura 14 or 16 series. Post a picture of your air dam as that could be the cause. It may work great at 45 but the additional forces at 50 may be causing the airdam to lose effectiveness
      • slyman
        • Jan 2009
        • 126
        Try adjusting your strut height one way or the other by about 1/8 of an inch. Your transom height should be around an inch
        when sitting flat on a table.
        • rc2266
          • 312
          The battery mod works great, I even ditched the airdam, was stable at 58, too bad I sold it, I miss that boat
          I'm married with children, you can't scare me!
          • Pete32200
            • 238
            I have done the Battery mod, air dam, sharpened rudder and installed a Prather B220 prop with the strut set at 1" on mine and it is pretty stable
            VS1 FE - UL-1 - Motley Crew - Miss Geico - Kintec Prince - Rio 51z - 1/16 Summit - 1/10 Summit - Ken Block Rally - Kyle Busch Truck - Losi Mini SCT - BL E-MAXX - Assoc FT SC10 - Wild Willy - Clodbuster - Sand Scorcher......
            • properchopper
              rcgoatbuild@snotmail.com
              • 6953
              The UL-1 was made with a lot of AoA to keep it loose and fast with the stock rtr setup. Power or prop it up and it does the dance.
              Decrease the AoA and she'll settle down
              • LOVE6S
                • May 2012
                • 521
                [ATTACH=CONFIG]86883[/ATTACH][ATTACH=CONFIG]86884[/ATTACH]
                Could you explain what AoA is please, thanks Shawn.
                • properchopper
                  • 6953
                  Angle Of Attack - the angle between the sponson and the water's surface
                  • LOVE6S
                    • May 2012
                    • 521
                    Ahhh, thanks.
