How To Stop Sponson Walking
  • TLeyde
    • Aug 2011
    • 88
    I have a UL 1 running a M445, have an air dam. At full throttle going down the straight guessing speeds of 50mph. It loves to do a sponson walk. How do I settle this thing down so I can keep the speed up?
    TL
  • detox
    • Jun 2008
    • 2310
    Its called chinewalk. I witnessed the same condition using the m445 prop and UL-1 hull, but never ran it enough to remidy situation
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3278
      Cut holes where the batteries go and slip the batteries halfway into the sponsons.
      • TLeyde
        • Aug 2011
        • 88
        I have cut into.the sponsons and 3/4 of the batteries are in the sponsons at the front most part of the hull.
        • LarrysDrifter
          Big Booty Daddy
          • May 2010
          • 3278
          Well, I got nothing.... Thats how I stopped mine from walking and it worked. Good luck to ya.
            • 7651
            My Miss Bud is doing this as well,it'll be fine but hits a chop and a walking she will go.My first hydro so I plugging in to this.
            • lenny
              • Sep 2010
              • 4296
              Try a different prop and see if it helps,
              I am using a x642 on my Hydro and it run pretty good with that.
              I have not pushed the setup yet, But speeds of 42 mph so far on 4s.
              http://forums.offshoreelectrics.com/...Hydro-for-sale
              ? ONLY IF THEY WORK
              • TLeyde
                • Aug 2011
                • 88
                Thanks for the tips guys. But I did what Larry said and I won't go backwards in speed Lenny. I've tried many props as follows M445, 40-52, 42-55, and 38-55.
                TL
                • lenny
                  • Sep 2010
                  • 4296
                  Hey,
                  What motor do you have in it and kv ?
                  Mine is a feigeo(sp) 10xl 1734kv on 4s,
                  The guy that had the Hydro made said that it should handle some bigger props.
                  I just have not tried anything bigger on it yet.
                  ? ONLY IF THEY WORK
                  • TLeyde
                    • Aug 2011
                    • 88
                    I know its weird, but I have the Pro Boat 1800KV motor in it with a Turnigy 120 esc.
                    TL
                    • lenny
                      • Sep 2010
                      • 4296
                      I think I may try propping up,
                      Your boat is 27"long by 14 1/4 wide and my boat is 24"long and 12" wide, 9"at sponsons.
                      ? ONLY IF THEY WORK
                      • TLeyde
                        • Aug 2011
                        • 88
                        Try a 42-55
                        TL
                        • TLeyde
                          • Aug 2011
                          • 88
                          It's not called "chinwalk", it's a hydro not a mono. Hydros have nonstops.
                          TL
                          • photohoward1
                            • 1614
                            Give it up. That's what UL1's do when they hit that speed. No prop on earth will fix it.
                            • mtbenjamin77
                              • 761
                              +1
                              You would have to modify the bottom of the sponsons to get rid of it. you need to add a step similiat to the PT supersport hydros
