Reciently I have had a customer that has been having UL-1 Connectors and solder problems. They are melting the solder in a one mile race oval on the 1/6th mile course during the fifth lap. Any one else having this problem?
Tags: None -
Dont cut the deans off. You have to desolder then resolder 5.5 bullets on
Sent from my DROID RAZR using Tapatalk1/10th scale miss dewalt, ul-1 insane fe-30, ul-1 jae 21 rigger, ul-1 powered lynx, UL-1 powerd delta force 26,
ul-1 sprint cat 21Comment
DO NOT CUT THE MOTOR WIRES! The coating on the motor wires will make it very difficult to resolder. Simply desolder old connectors then resolder on new beafier ones. The thin factory 4mm motor connectors heat up too easily causing them to unsolder themselves from motor leads.Last edited by detox; 02-14-2012, 07:13 AM.Comment
Ya know the old connectors and solder on the early (first) UL-1 motors were fine never any problem (on the smaller boat). The SV27 solder and connectors always had to go and I would just hard solder and prewire wrap the connection. I guess the bean counters thined it down on both in the end.Last edited by RandyatBBY; 02-27-2012, 12:22 PM.Comment
I had cold solder joints on the motor connections on my first gen UL-1.
Basically just the heat shrink holding them together but I swapped them out and it's still going strong.Namba District 16
1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.Comment
I put in the old UL-1 motor in my SMJ 30 (Short for Smoken Joes 30 inch) and on the fifth lap they melted the solder. I hard wired and wrapped with several strands of lead wire. In all test the 5 year old ESC and motor are just fine. I sorta inner weave all the strands from the motor to the ESC then wire wrapped it and shrink wrapped the connection.Comment
I put in the old UL-1 motor in my SMJ 30 (Short for Smoken Joes 30 inch) and on the fifth lap they melted the solder. I hard wired and wrapped with several strands of lead wire. In all test the 5 year old ESC and motor are just fine. I sorta inner weave all the strands from the motor to the ESC then wire wrapped it and shrink wrapped the connection.Nortavlag Bulc
