Flex Cable
  • hobby_man
    • Sep 2011
    • 103
    Flex Cable
    The flex cable twisted off the shaft where the prop mounts, this is a brand new boat, I got 3 laps when it twisted off, is this a known issue with the stock flex shaft?
  • hobby_man
    • Sep 2011
    • 103
    I ended up soldering it,,,poor joint from the factory
    • hobby_man
      • Sep 2011
      • 103
      turnigy's fit real nice with velcro removed
      moved the RX to the side, why have it sit in the water
      routed the ESC wire through the moter mount and wraped with a covering
      rotated the servo horn 180 deg. and moved the control rod out 2 holes (had to drill out)
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3278
        Your last post is a bit hard to read. You moved the RX to the side so it doesnt sit in water? Why would you get water inside the boat? How much are you getting?
        • hobby_man
          • Sep 2011
          • 103
          no water in the boat,,,,yet, I think it makes more sense to have the rx on the side out of harms way.
