Ul1 question
  • Mike whiting
    • 120
    Ul1 question
    I want to put a fuego 540XL and A seaking 180 In my ul1 but dont know what size 540xl to get Can someone help me out? And is that a good combo
  • m4a1usr
    Fast Electric Addict
    • 2032
    How many cells or packs do you want to run? Also how fast do you want to go? If you want to stick with something stock get a 7xl but you wont be running a large prop. Also why run a 2 pole motor when you can get a 4 pole that will perform better? Look at this one, same price but 4 pole http://www.offshoreelectrics.com/pro...prod=keda-4074 Or you can get a Tacon 4074 if you dont like the Keda. But if your new to FE boats a Feigao may not be a good choice. Its a good motor. But the Keda/Tacon will perform better and for the same price.
    John
    Change is the one Constant
    • Mike whiting
      • 120
      Not really sure maybe at least up to 6s one or two packs preferably one for weight. Iam new to boats so thank you I want my boat to do about 60+ I like The keda but what Suzette do I need
      • jamie
        • May 2011
        • 179
        [QUOTE=Mike whiting;312356]Not really sure maybe at least up to 6s one or two packs preferably one for weight. Iam new to boats so thank you I want my boat to do about 60+ I like The keda but what Suzette do I need[/QUOTE
        I have been messing around with mine for a while now and i think with this boat you should stick with 4s like i have .... its plenty fast believe me
        Leopard 3674 2650 kv with a swordfish 200 and the softest timing setting.
        2s2s 5000 40c lipos and an m545 will get you to 60 mph keeping it on the water is the tough part
        Airdams, c.o.g, turn fins, numerous props all wont make it an easy boat to stay stable for long over 60 IMO.
        Its a great RTR hydro just put a prop and a decent set of bats. in it and enjoy it
        • Mike whiting
          • 120
          so With tHat sEt up You still run the Bats in seEries what abouy 1 4s or 6S
          • jamie
            • May 2011
            • 179
            4s 1p is fine but the length of the lipo becomes an issue. I just ran 67 mph on 2s 2s on my ul1 ... BUT not stock and half inch air dams all the way to back of sponsons and its purely a saw application.
            • Mike whiting
              • 120
              Cool I am excited what size c
              • Mike whiting
                • 120
                Nevermind I see you already answerd that above thanks
                • jamie
                  • May 2011
                  • 179
                  http://www.hobbyking.com/hobbyking/s...dProduct=14691
                  I run these the nano's are always on back order it seems
                  Was just looking and found a 4 s 5000 40c that will fit.
                  Im going to run these as our class in Aus. says one lipo only
                  http://www.hobbyking.com/hobbyking/s...dProduct=10307
                  • Mike whiting
                    • 120
                    Cool do you like running deans and also what size connectors do you run to connect esc and motor
                    • jamie
                      • May 2011
                      • 179
                      My leopard is 4 mm to the esc and i use all 5.5 everywhere else .
                      Deans are ok but tend to get hot with longer run times, i swapped them out when i went to the other motor / esc package
                      • Mike whiting
                        • 120
                        Is 4mm better than 5.5mm is 5.5mm ok to use I just want to get the right things
                        • Mike whiting
                          • 120
                          Will the deans melt and how do you run in series with bullet connectors or how do you make connections I should ask
                          • jamie
                            • May 2011
                            • 179
                            The 5.5s are the way to go but the 3674 leopard has 4 mm connectors and its not good to mess around with the motor cables as some are actually part of the motor windings, i believe you can heat them off and resolder, but i didnt want to mess with them as there seems to be no heat dramas so i leave them alone.
                            • jamie
                              • May 2011
                              • 179
                              Dont know about melting but they do get mighty warm and series is pretty simple positive of the first battery to esc red wire. negative of first battery to positive of second battery and the negative of the second battery to the black esc wire. Your standard ul1 is wired up this way with the deans connectors. Do a search of the o.s.e store in tips and info to be sure before you do anything, i dont wanna blow up your new lipo's for ya LOL
