spektrum?
  • macz
    • Jan 2009
    • 118
    spektrum?
    I was thinking of getting the new spektrum Dx3c for the UL1 are their marine receivers decent? Can the antennas be inside the UL1?
  • tunnelvision
    • May 2010
    • 685
    They are great. I use the Spektrum MR200 and MR3000 receivers with my DX 2.0. You won't be disappointed. Range is great and performance is reliable. Thats all you can ask for imho.
    Go Fast...Turn Right...
    • Diegoboy
      • Mar 2007
      • 7245
      If I decide to retire my FM, the dx3c is what I will consider.
      • macz
        • Jan 2009
        • 118
        Do u just tape the mr200 antennas to the inside of the ul1?
        • tunnelvision
          • May 2010
          • 685
          Need to run one inside the hull parallel to the water and the other vertical. So you would need to install a mount for the antenna.
          • macz
            • Jan 2009
            • 118
            I heard that u can run the antennas inside with no problems..
            • tunnelvision
              • May 2010
              • 685
              You can try it but range test it first and make sure you have your fail-safe programmed properly. Its not how its meant to be used so be careful if you try it.
              • Vinnie909
                • May 2011
                • 30
                i run my Spektrum antenna inside the haul in my EKOS and works perfect!
