i' ve got a UL-1 hull with no configuration, somebody could help me?I would like to reach 50mph or + thanks
UL-1 set up
Tags: None
UL1- 1515 castle/neu / 240 swordfish
SV27- with UL1 running gear
33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P -
Stock UL-1 motor and controller on 4S....with the right prop will get you there as well...Grand River Marine Modellers
i think the ammo 2300kv with stock esc and grimracer 40/57 -3 blades is good according to some research... thanksComment
Stock motor is better, JMO. Drop the strut to a little over an 1" and slap a L40x57 prop on it. You should hit or be close to 50mph, with a simple prop change.Comment
ok stock motor is ammo 2030kv I add to my list! and it is true that this boat is to be used in calm water, a little wave at full speed and it is the insured swimming! grrrr
Define calm water........Grand River Marine Modellers
I find that my UL-1 runs faster on water with slight ripples instead of glass flat. I'm at 45 mph with with the Girm lifter 3 blade S&B, everything is else is stock. I wanna hit the 50 mph mark also. I little more adjustment work and I'll get there.Aquacraft UL-1
Aquacraft Rio 51 Gas (modified)
Zipp Kits Easy VeeComment
