ok people, this is how you get cooling tube back thru the hull
  • dana
    Banned
    • Mar 2010
    • 3570
    so many people on here doing all sorts of stuff to get the cooling lines back thru the hull. heres a quick pic and how to do it. cut about 3 xtra inches of tube, now cut it to a long point, now you can feed the thinned end thru, pull it thru from the other side and cut it flush. simple
  • scoota
    FE DOWN UNDER
    • Dec 2008
    • 409
    good idea ,thats what use to do, but i still like my idea with the copper tube thru the hull , that way you know this is no restrictions of water flow by the tight fit of the hose going thru the hull , each to there own ....
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
    • Grimracer
      • Nov 2008
      • 656
      If you have to enlarge the hole a tick and cut a 60deg angle on the water line.. slip it thought and pull.. trim square..
      Its allot like you are doing just not as drastic a angle on the line.. Good job!
      Grim
