53.1 mph stock UL-1
  • 6S HYDRO
    • 1320
    53.1 mph stock UL-1
    GOT SOME GPS PASSES IN, 53.1 MPH W/ 40/52-3- STRUT NEUTRAL , 5S LIPO CONFIGURATION 1 2S AND ONE 3S PACK ON TOP OF EACH OTHER PERPENDICULAR TO THE MOTOR ALL THE WAY BACK.
  • 6S HYDRO
    • 1320
    Saw style runs guys, i know i know
      • 9479
      For some reason I cannot get my UL-1 to run 5s..
      It goes into some studder mode!
      • longballlumber
        • 3119
        I hope you guys are not trying to run the stock UL-1 controller on 5S?!?!?!?!?!?!? I don't think that is what it was designed for...
        • 6S HYDRO
          • 1320
          Exactly what the title says- stock ul-1. Have been running 5s on 3 of my sv's for over a year now. As long as your careful and watch your temps, you'll be fine
          • scoota
            FE DOWN UNDER
            • Dec 2008
            • 409
            what about the cut off voltage on the UL-1 esc its set for 12 volts , that will kill your 5s set up if your not careful . i only bring this up for the newbes thinking they can run 5s with no problems ...
            UL1- 1515 castle/neu / 240 swordfish
            SV27- with UL1 running gear
            33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
              • 9479
              if one always runs your boat till the lvc kicks in, they could be taking their batteries down to far and hurting them..
              runs should always be timed..
              • 6S HYDRO
                • 1320
                I never run till cut off on 4s unless you want to puff the batts, and i would absolutely never run on 5s for more than a few laps.
                  • 9479
                  I agree bro!
                  that's a sure way to kill lipos..
                  • 6S HYDRO
                    • 1320
                    Originally posted by brushless55
                    for some reason i cannot get my ul-1 to run 5s..
                    there's no way for the esc to detect over voltage. And those esc's are rated to 20 volts. Something's probably wrong w/ your 3s connector
                      • 9479
                      not sure?
                      I even put on a BEC and still it studders..
                      • 6S HYDRO
                        • 1320
                        Take off the bec- thats prob the problem. The stock ones handle it fine, like i said thery'r rated for 20 volts and ive been doin it on the 45a ones forever. Like i said before watch temps and short run times and you'll be fine
                          • 9479
                          the BEC is not the problem just added insurance...
                          it did this before I put it on..
                          I'm thinking its my lame 12c batteries that's causing me issues..
                          when I run 4s I have some nice 30c packs that get me 50mph
                          Think I will put in an order for some good 3s packs this week, maybe zippies
                            • 9479
                            Ok I tried my new 2s and 3s 30c packs and dang!
                            I was running a S220 prop and this boat shot out of the water and was a handfull to get to top speed.. It kept lifting the left sponson up and out of the water.. Looked cool, nuts power!
                            after about two minutes my UL-1 took off all by itself?
                            come to find out my external BEC was only rated to 3s!
                            and when I put 4s to it and took off the bec, some smoke came from my rx!
                            • NitroVal
                              • Jun 2009
                              • 423
                              As far as Im concerned you are all liars unless we see some vids!!!
                              The RTR Nightmare- Electric King of Shaves
                              Now with 540s- 62mph
                              New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
