GOT SOME GPS PASSES IN, 53.1 MPH W/ 40/52-3- STRUT NEUTRAL , 5S LIPO CONFIGURATION 1 2S AND ONE 3S PACK ON TOP OF EACH OTHER PERPENDICULAR TO THE MOTOR ALL THE WAY BACK.
53.1 mph stock UL-1
For some reason I cannot get my UL-1 to run 5s..
It goes into some studder mode!
I hope you guys are not trying to run the stock UL-1 controller on 5S?!?!?!?!?!?!? I don't think that is what it was designed for...Comment
what about the cut off voltage on the UL-1 esc its set for 12 volts , that will kill your 5s set up if your not careful . i only bring this up for the newbes thinking they can run 5s with no problems ...UL1- 1515 castle/neu / 240 swordfish
SV27- with UL1 running gear
33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2PComment
if one always runs your boat till the lvc kicks in, they could be taking their batteries down to far and hurting them..
runs should always be timed..
not sure?
I even put on a BEC and still it studders..
the BEC is not the problem just added insurance...
it did this before I put it on..
I'm thinking its my lame 12c batteries that's causing me issues..
when I run 4s I have some nice 30c packs that get me 50mph
Think I will put in an order for some good 3s packs this week, maybe zippies.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Ok I tried my new 2s and 3s 30c packs and dang!
I was running a S220 prop and this boat shot out of the water and was a handfull to get to top speed.. It kept lifting the left sponson up and out of the water.. Looked cool, nuts power!
after about two minutes my UL-1 took off all by itself?
come to find out my external BEC was only rated to 3s!
and when I put 4s to it and took off the bec, some smoke came from my rx!
