Bought a mini wildcat about 2 weeks ago, and now i wanna go brushless. What size brushless will i need to go 50mph +? I know its dual motors and it will need two brushless set ups. Also how do you think it will handle at 50mph
Brushless wildcat
I'm already on it. Have a thread going on it and a brushless setup on the way!FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Just a set of these motors? What esc would i use to power these?
http://www.offshoreelectrics.com/pro...prod=fei-380-SComment
Check out this thread; http://forums.offshoreelectrics.com/...ad.php?t=14585
And this one: http://forums.offshoreelectrics.com/...ad.php?t=14882
The motors are tiny, but there are two bolt patterns in the mount, less than 380 sized holes.
I'm starting with a 35-40 amp setup and if it's not enough, going up to 60amp. But battery life becomes an issue at that point.
Jeff Wohlt can make specialty couplers for whichever motor setup you choose. www.rcraceboat.com, just email him and ask.
The props are 1/8th.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
how about two of these?
http://www3.towerhobbies.com/cgi-bin...?&I=LXUFF0&P=7
Those motors would last about 10 seconds at 9000kv.................. As forescott mentioned 3500-4000kv on 2s would work alright. Something along these lines
http://www.hobbyking.com/hobbyking/s...hless_Inrunner
Fightercat sniffed these out..............whole setup for $40......need two of course.
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
http://forums.offshoreelectrics.com/...est!&highlight=Comment
HK has a few 35-40 amp esc's. They need to be conformal coated or silicon sealed though. http://www.hobbycity.com/hobbyking/s...ies_35-40A_ESC
You can also add a water cooled heat sink instead of the one that comes with it. There's some floating around, ETTI makes them and OSE has them.
Whatever motor you choose, size the ESC above it's max amp rating and you should be OK.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
I did a single brushless mini vee 28-47 2700kv 40 amp esc 3s and 4s on stock hardware. Durability becomes an issue quickly with this much power. Also the weight to power ratio get skewed quickly as it is hard to have something so fast and light keep in the water considering at 30 mph a ripple is a titlewave.About 300$ in to it im now looking for a 16-18" fg hull to tranplant my goodies.Probably a bby warzone jr since i have all the hardware from a brushed one i had many years agoComment
Everybody always wants to go faster. Remember, there is a point at which the boat becomes uncontrollable! What's the point!!!?Mini Cat Racing USA
This esc you showed me has bad reviews of burning up. also how hard will it be to wire in two motors? Also what kind speed will i see from this set up you have shown me?HK has a few 35-40 amp esc's. They need to be conformal coated or silicon sealed though. http://www.hobbycity.com/hobbyking/s...ies_35-40A_ESC
Whatever motor you choose, size the ESC above it's max amp rating and you should be OK.Comment
