Brushless Wild Cat?
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    Brushless Wild Cat?
    I have a 500' body of water really close to me that's small for a fast boat, but fun in the wild cat.
    What I want is to use my standard transmitter/receiver setup...
    ... 5+ more MPH and 20 minutes of run time.
    It's pretty clear that the mounts can be taken out and the motors can be changed and there's room for an ESC, maybe two...
    What I don't know is the Kv of the stock motors and the size?
    What kind of brushless setup would work?
    Much smaller than I've worked with in the past and probably best to ask before tearing in to it. =)
    ________
    FX-1
    FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    Still looking for the Kv of the stock motors. They are Aquacraft T270
    Can Diameter: 24mm (0.95")
    Can Length without capacitor and shaft: 30.5mm (1.20")
    Overall length including capacitor and shaft: 57mm (2.25")
    Shaft Length: 10mm (0.40")
    Shaft Diameter: 2mm 0.08")
    I think it could be a fun little boat with twin brushless.
    If I can get enough power out of it, I'll make it my rescue boat!
    ________
    BMW M51 HISTORY
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      OK. Parts ordered! This is going to be a crazy little thing!
      The next question, is prop size. Tiny little guys, anyone know if I can find a counter rotating pair?
      Looks to be an M3 nut. I'm guessing a 1/8th prop will work.
      ________
      Daihatsu Taft History
      • forescott
        Hopelessly Addicted to RC
        • 2686
        How about the octura x430 left and right??
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          Hmm. I think those would work.
          I did find out that these are 3mm shafts, so again, I think a 1/8th is in tolerance (.17mm)
          I'd really like to stick with plastic and cheap though. I have a set of 32mm counter rotating props that I think would work, however they are for 4mm shaft. I think I can find a 4mm OD, 3mmID tube, but haven't looked yet.
          ________
          Medical Marijuana
          • forescott
            • 2686
            AAAAAH! venom props!
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              Yep. Cheap $3 props. That reminds me, I have to look up 3-4mm tubing.
              ________
              VAPIR ONE REVIEW
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3480
                Perhaps a #128 inside of a #129 brass tubing?
                http://www.offshoreelectrics.com/pro...dh-ks-brass-tb
                ________
                America'S Next Top Model Forum
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3480
                  OK, got the prop thing figured out. Just waiting on Hong Kong Post!
                  Have the coupler thing all set as well.
                  In case of failure, I have an alternate configuration in mind... HobbyHot has a 60a esc/motor combo with a water cooled inrunner that is very similar in dimensions, but has a larger motor shaft. Looks like it will bolt right up. My biggest worry then would be controlling it. Way too much motor for this little guy. Who knows though, it might make it really fun! It's about $80 bucks though, so will try the bolt in $30 Turnigy solution first.
                  My speed/time goal is 30 mph with 15 minutes of run time. Either the Turnigy or the Hobbywing setup will do the trick for sure!
                  ________
                  Ford Xw Falcon
                  • turboed13b
                    • May 2010
                    • 9
                    care to provide some links of the parts you are using?
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3480
                      Sure!
                      Plan A:
                      2900Kv Inrunner drop in replacement
                      http://www.hobbyking.com/hobbyking/s...idProduct=4197
                      35-40a ESC for 2900Kv inrunner (2-3s Lipo)
                      http://www.hobbyking.com/hobbyking/s...idProduct=6461
                      Plan B:
                      SwangHobby(HobbyHot) 60a ESC/Water Cooled motor Combo:
                      hobbyhot.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, hobbyhot.com has it all. We hope you find what you are searching for!
                      I plan on using the 32mm Counter Rotating Venom Propellers with a #128 brass tubing insert to fit as 1/8th props. I'll experiment with both rotating inwards for performance and outwards for stability.
                      ________
                      IOLITE VAPORIZER
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3480
                        Ha! Swang's out of the 60a/Inrunner combo! Guess it was a good deal!
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3480
                          The drop in HK motors should be here tomorrow!
                          Nothing fancy, 2s and little 32mm props to start. The goal isn't massive speed runs, rather a good increase in speed and a nice long run time.
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3480
                            The babies are heeeeeeeeeere!
                            So tiny!
                            Looks like I'll have to shave in a flat spot on the shafts, but otherwise, good to go!
                            I'll get some photos of the mounting/installation process. The aluminum cooling coils should fit right on.
                            The special instructions on these ESC's say 2s only if over 2000Kv, which I'm at 2900Kv on these lil guys. So, 2s it is. There's room for two 2s 2200kv lipo packs, so will see how the power/run time situation goes.
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3480
                              OK, parts in! However, in a 50/50 chance I setup the props spinning outward.
                              Hmmm, should I set them up counter rotating in or out?
