the thing i found when i put 370 brushed motors in mine is the boat turn to the right i had to offset my battery and use the rudder to make it go straight again. i say stick with counter rotating props.
Brushless Wild Cat?
Ah, cool. Good to know! When I get some time again, I'll get the brass straightened out and the wires running smooth and she'll be good to go. The ESC's basically have to be mounted inbetween the motors to help keep the cog towards the back. Can't wait to run it in real water. =)FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Ok, counter rotating and ready to go! Had some time while I was watching paint dry today. Had to straighten out the brass tubes for the wire drives to spin freely. I moved the wooden supports and re-glued them further towards the motors. They had the stock tubes bent like and s curve. Don't understand why?
Against my better judgement, I decided to do a bench test and open her up to see if I could generate some heat! I would rather have it fail on the bench.
None, really. Didn't get hot at all, in fact, was kinda fun seeing what I could blow off the workbench with it. Good mount of air flow. Had some fun for a few minutes with my little remote control fan.
I'm sure I'll get some heat with the props in the water. =)FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Ah, thought I would add... the cheapie ESC's have a slight delay on acceleration then catch up with a punch... like they are building up and then go.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Of course it broke a shaft today... I think 047 is a bit too small of wire.
Not sure what to do at this point. It would be really great to find a left hand lay cable!
For now, I have a new pair of drives coming and I'll try the stock props both CCW and see how that goes.
It was a rocket! For a minute.
I think the wire broke because of the s in the tubing. Wire drives can take a slight curve, but an s would be bad I think. You might try Jeff Wohlt he may be able to make you a left & right lay cable for it. Defintly go to something bigger than the stock drive cables. I don't think they'll take the power of the bl motors. Jeff Wohlt can also make motor couplers.Comment
Yep. Already talked with Jeff. He doesn't have the 3mm drives.
I am going to try to straighten the brass some more. I really think they are breaking like you said, because of the double bend, even if reduced to only a slight bend, it's still an s and that's where the wires are breaking.
I guess the way to do it is to heat the tube up with a soldering iron and loosen up the epoxy? I've never messed with removing epoxy like this. If I can get it out, I can replace it with a straighter tube. It's just #128 tubing.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
New cables are in. Might get the prop wet this week!FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
The port side wire snapped and put a slight bend in the shaft. Just enough to make some vibration.
The ESC fried, so now there's only 1 ESC working. So I pulled the Rx for another project and shelved it.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Updated photos by request:FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Next HK order, I'm planning on another ESC & motor. Will give it another try. Was wicked fast when it ran the first time. =)FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
This ESC and motor are "drop in".
Motor:
ESC:
