Need help ugrading my Motley Crew
Check out the store here and kinetec, just a plain old 540 mount from china, I really like the Etti mount to though.
I don't use the watercooling in the mount, would rather have a non cooled version but they were out of stock when I did the re-build. I don't think they do much on the shaft end of the motor.
I've been using JB Weld to install mounts for a while, never had one come loose. A good number of us are using it for that now.If my boats upside down then who owns the one I thought I was driving the last two laps?
I think it's stronger than regular epoxy. Just standard JBWeld, Great for stuffing tubes as well. Also stays where you put it, just flows enough to smooth the joint.
I've never added extra glass or carbon to hold a mount in with JB, always used to reinforce epoxy.If my boats upside down then who owns the one I thought I was driving the last two laps?
JB Weld is way stronger than Epoxy.42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
I tested them by peeling off left overs from mixing board and you can't break it, almost like metal, WestMarine and Zpoxy are great stuff, however, epoxy is more brittle. It cures extremely hard, but if you twist a thin piece by itself, it will break. I use epoxy to reinforce hulls with FG cloth or mix it with heavy filler. JBWELD can be used alone to secure stuffing tube.
So to me they have different purposes.
just my .02Too many boats, not enough time...
I believe you, I did something like that, put some on a piece of aluminum, stuck to it like mad and was hard as a rock, like metal really. I notice on the package though, JB Weld says 900psi and the Epoxy says 2,000 psi, so obviously these numbers can be manipulated by the companies or something.Comment
Gents if one wanted to only upgrade the prop on a MC what prop would be the best choice ?
Although the lure of motor/esc upgrades are attractive I would like to just get the best performance from it in stock form which I think is pretty good from what I have been reading.
I do however plan to use 4s in parallel
I hope there are some carbon fiber trinkets to make for these boats
Thank youComment
Grim 42-55 works good, or a X442 Octura... Always keep an eye on temps when changing props...Motley Crew, Neu-Castle 1515 1Y 2200, 22 Volts, 180A ESC, Custom Motor Mount, .187 drive cable. Aero mod.
Best 74.1 mph, Average 71 mph.Comment
