Need help ugrading my Motley Crew
  • RCnerd
    • Jun 2012
    • 56
    Hello Everyone,
    I have been reading a lot of information on this site and it is very informative and overwhelming at the same time!
    I have a blast driving my MC but, like most of you guys, i want it faster. I have the following upgrades already:
    1-OSE Flex Shaft
    2-OSE motor coupler
    3-42x55 prop
    My driving consist of super glassy water. I would like to drop in a new motor and ESC (with LVC). I need your help!
    1- What motor and water jacket would you recommend? Will I be able to bolt it to the existing motor mount?
    2- What ESC do you recommend?
    3- What will be the best prop?
    I really appreciate any help that you guys can give me.
    Thanks.
  • Doby
    KANADA RULES!
    • 7280
    Define "faster".....
    Grand River Marine Modellers
    • RCnerd
      • Jun 2012
      • 56
      Haha! I would like to get as close to 50 as possible with the same battery setup that i use 4S1P.
      What do you think?
      • Doby
        KANADA RULES!
        • 7280
        I get 47 consistently with mine in stock form...just need to play with struts and props....no other mods required.
        • RCnerd
          • Jun 2012
          • 56
          What Prop are you running ?
          • Doby
            KANADA RULES!
            • 7280
            I don't like to give out prop specifics as its pushing the stock electronics, but so far for two seasons they have held up... it is an Octura X Series,,,but its severly modded.
              Near 50 mph with the stock electronics is possible but probably not for long run times. I almost hit 50 with an m445 on my stock AQ 1800 with 'stock' AQ ESC and 4S1P - but I don't run for more than ~2 minutes for a race heat. Even on 100*F days nothing comes in over 130*F, mostly less. The boat is running pretty loose to get that performance level. For a "safer" 50 mph I'd go with a Leopard 4074/2000 motor and an ESC with a 120 amp minimum rating. With the m445 that should get you to 50 with more head room to spare. Below is my Motley Crew build:
              http://forums.offshoreelectrics.com/...-Crew-Re-Build
              • RCnerd
                • Jun 2012
                • 56
                Wow that is a killer build! Thanks for the information. Do you know if the Leopard motor will mount to the stock motor mount in the motley crew? I am new to FE boats so I am not ready to attempt putting an aftermarket motor mount in the hull just yet.
                • siberianhusky
                  • Dec 2009
                  • 2187
                  You can, personally I wouldn't. I bent the stock mount in mine running a Castle 1512 it's shorter than the Leopard.
                  Installed an aftermarket floor mount, trimmed the stuffing tube shorter so everything lines up nice.
                  I personally think this puts the motor in a better location for adjusting the cg, it also drops the height of the motor quite a bit thus lowering the cg in the hull.
                  Epoxied some hardwood rails in the bottom of the tub at the same time, really stiffened things up. The inboard end of the stuffing tube doesn't move anymore when you adjust the strut.
                  I also installed a SV27 rudder on mine, it has a built in water pickup. I use both inlets, one for the esc the other for the motor.
                  I can run for a full 3:30 in the 50 ball park with no heat issues at all with the stock setup, Now I usually run a proboat 1800kv motor in it, lower amp draw for the same prop. Might just be a "good" proboat motor. I only have the one so no comparison. I also did some work on the bottom of the hull to improve it, flat sanded and leveled the sponson bottoms, then gave them a scuffing after I painted it.
                  Had a Leopard 4074 in it, the Castle and the spec stuff, I find the boat to be the most fun with a stock type setup. No sinking feeling and the associated repairs when I blow over at it's intended speeds.
                  I have an H&M cat that has cartwheeled down the lake at 60mph wiht no damage at all, Last time out in rough water must have crashed it at least 6 times, the Motley would probably self destruct if that happened. The difference in hull quality is remarkable. There is a pretty big price difference to though.
                  • RCnerd
                    • Jun 2012
                    • 56
                    Thanks for the information. I will just leave mine stock for now as it is still fun. However, I would like to get an upgraded cat. Which H&M cat do you have and what is your set up (If you don't mind me asking). I really would like an upgraded boat that will fly!
                    • siberianhusky
                      • Dec 2009
                      • 2187
                      http://forums.offshoreelectrics.com/...2&d=1336932553
                      Here is the inside of mine now with the motor mount, rails and how much I trimmed the stuffing tube.
                      I believe that moving the motor back allows you to slide the batteries forwards, keeping as much of the mass as possible near the cg. INstead of having the motor forwards and the batteries almost all the way back.
                      The wood I used for rails is some off cuts from a guitar fingerboard, super hard, dense stiff stuff called padouk added a couple light ply cross members as you can see.
                      • RCnerd
                        • Jun 2012
                        • 56
                        Nice work!!!
                        • siberianhusky
                          • Dec 2009
                          • 2187
                          I have a drifter S 26" long running a UL-1 motor with a swordfish 120 esc.
                          Most of my stuff is powered by spec motors, I get a big kick out of tinkering and tuning. I get more excited getting an extra mph by tuning and setup than throwing more power at it and getting 10 mph.
                          I also find the $/fun ratio to be awesome with the spec stuff. I used to run big nitro boats, still can't believe the performance and reliability you can get out of a 30" 350$ boat. 60% nitro fuel and sheets of glow plugs got very expensive after a while. Was about ready to go to gas until I saw a brushless motor and lipos run, 2 weeks later had an electric setup!
                          • RCnerd
                            • Jun 2012
                            • 56
                            As a minimum I would like to upgrade the ESC so I can have LVC. Is there one that you would recommend? There seems to be a lot out there. I would assume I do not need anything over 120 right?
                            Thanks.
                            • siberianhusky
                              • Dec 2009
                              • 2187
                              Pretty sure the stock esc has a lvc, it's a pretty good unit I've put spikes of over 100 amps through one and averages for short runs of 80.
                              I time my runs and don't rely on the lvc in any esc.
                              SOme people don't like them but I've had great luck with swordfish 120 escs just have to give them some water proofing. A lot cheaper than buying a new stock esc although they do come up on the swap quite often when people decide to upgrade.
                              IMO I don't really think it's worth upgrading a RTR boat too much, they are manufactured to a price point and the quality only goes that far. If they are run as intended they will last for a long time and give tons of fun. Once somebody decides to step up the speeds I've found it actually cheaper in the long run to build something out of higher quality components that can handle the eventual crashes at high speeds.
                              The MC is a great design and I know it can run great at some pretty impressive speeds, to only problems is the hull and hatch just needs to be a little stronger. I'd love to have a vacuum bagged epoxy carbon fiber version! If is only existed.....
