5s lipo on motley crew .
  • belltec50
    • May 2012
    • 51
    Im a noob here,I have a motley crew,all stock with a 42/55 prop balance race prep has been done and 5.5 bullets.I want to put 5s lipo on it ,and i have a ccbec laying around. does the batteries need to be in series or parallel.thks for your help.
  • dana
    Banned
    • Mar 2010
    • 3570
    Series.
      • 7990
      Wait a minute. If you have two 5S packs, they must be connected in parallel, NOT in series since that would give you 10S! If you have a 2S pack and a 3S pack, then connect them in series for a total of 5S. Follow the advice in the owner's manual and time a 2 minute run with the new setup to make certain nothing overheats.
      • dana
        Banned
        • Mar 2010
        • 3570
        Indeed. I shouldn't assume he's using a 3s and 2s to get 5s. I figured 5s packs wouldn't fit. fluid explained it better than I.
        • belltec50
          • May 2012
          • 51
          I'm using a 2s and3s thks for all your help
            • 9479
            5s in parallel
            they will fit
            • belltec50
              • May 2012
              • 51
              I have't tried the 5s yet ,but i did go from a grim 42/55 prop to m455 on the mc and man it was worth it!!!!
              • D for Dummy
                www.dfordummy.com
                • Mar 2012
                • 55
                I run two 2s, 4s total in mine. If I run 5s total what do I need to know about matching my existing 2s? does the c rating or mAh need to be the saem between the 2s and 3s?
                Aquacraft: Revolt 30, (Three) Motley Crew / ProBoat: 1/12 Miss Budweiser, Stiletto 29 / Venom: P1 KOS Fountain with all Revolt 30 hardware
                http://www.youtube.com/user/dfordummy/videos
                • martin
                  • 2869
                  The 42/55 prop is only 2.16" pitch the m445 is much higher pitch at 2.48" + being an m series the ears have been removed ( detonqued ).
