alright i really appreciate the help guys
Cold weather affecting speed?
Can you post of pic of the items you let the guy at the lhs solder? I don't trust the guy based on his advice. Just wanna make sure he did things correct.
Sent from my T-Mobile G2 using TapatalkComment
i took a picture but its not letting me upload it...he said that it was good(hold on now, i know what your thinking) and i looked it over carefully and i know that it is good. I know that i am still a pretty new to this but i know that the connections were good and it all works. I even tested it and it works like a charm...if it is necessary, i can tell you what connector is on each wire....Comment
Standard on esc: Female on -, male on +
* Make sure the bullets are covered very well by heatshrink.
There also should not be any jumper between the esc. You should only have 2 power wires coming off the esc, using the bullets eliminates the need for the series jumper.Comment
so i could just cover up the bullets that wouldnt need to be used.... it wouldnt hurt anything if i kept the jumper in...Comment
I had a feeling he was going to do that. The jumper adds unnecessary resistance!
To connect your batteries in the series circuit without the jumper take the + of one battery and connect it to the - of the other battery. The safest way to hook up your setup is to hook 1 battery negative to the esc negative, take the second battery + hook it to the esc + and last of all connect the 2 batteries. That will help reduce the chance of shorting out a battery to itself which is easy to do with bullets.Attached FilesComment
what are some good upgrades to make after 5.5mm bullets? ie.. power systems, scuffing, shapening rudder, rounding bottom of rudder, blueprinting the hull-how is this done and is it necessary?Comment
