I have a motley crew with stock electronics and upgraded ose flexshaft. I am running an m445 prop that is s/b. The lipos are 7.4v 100c 6000mah maxamps(they came with the boat when i bought it and i know they are very overpriced). I live in michigan and i ran my boat last about 2&1/2 weeks ago. The temp outside was probly about 40 degrees but no snow. With this setup, i only got 38 mph an i hear of people getting mid to upper 40's. I know that the cold weather affects the power of the lipos, but it still seems a little sluggish for this setup. I adjusted the strut more positive because it was running pretty tight. Would the cold weather and too negative on the strut slow the boat down that much? Also, i have read that the water is thicker when cold due to the molecules lumping together. I am fairly new to rc boating, but want more speed..... can someone help me out?
Cold weather affecting speed?
Tags: None
It used to be that LiPos had higher resistance at temperatures under 100*F and thus put out less power. With curent tech LiPos this is much less pronounced. I was reminded of this yesterday when an older set of packs (~4 years old, 25C) was run in 75* weather. The first couple of laps looked pretty pathetic, but then as the packs warmed up the boat picked up quite a bit of speed. The effect is much less with current packs, but then I haven't run at 40*F for many years. I strongly suspect that the low temperatures are robbing you of power, not the minor changes in water density.
I raised the strut about 1/6 inch and it went 43.2 mph....that was probly the main problem. The deans connectors were so hot....170 degrees! Is this setup just drawing too much amps or what...esc and motor were in the 70's (water was in the 30's) and the lipos were 135 degrees. I ordered some 5.5mm bullet connectors....but the guy at the hobby shop told me that it wouldn't do anything. Is it true?....the esc has 14ga and lipos have 12ga wire. I am pretty worried about the deans getting so hot...what should i do?Comment
What you should do is stop listening to the guy at the hobby shop. 5.5 mm connectors will substantially decrease the connector temps. Make sure you have a decent soldering iron to create a proper joint.Grand River Marine Modellers
https://www.facebook.com/search/top/...ne%20modellersComment
I realized the people at my LHS didn't know much about boating when the guy at mine tried to convince me the PB Widowmaker (which was a turd), was faster and a much better boat then the UL1 because it at a higher kv motor and that made all the difference. As I gave him the (your an idiot look) he let me be as I continued to browse.Comment
he told me that deans have the lowest resistence on the market and the bullets would just melt together and create a bomb. Its only a 60 amp esc and i am running 100c maxamps and an m445 is this just too many amps for the esc to handle? Are the batteries too powerful? Prop too big? It seems to me that based on what he said that i would either need batteries with a lower c rating or bigger esc...i am scared because i dont want to have the batteries explode from the connectors melting..... He told me that the people on the forums dont know what they are talking about. he also said that no one has problems with the spartan with the traxxas plugs..... could this because it has a bigger esc?Comment
Its because the plugs arent the Spartans problems. They guy is a moron. He needs a job where he has zero interaction with the general public. You will find some good info here. Yes, there are morons here too that will give false information, but the 3 guys that posted in this thread already are good guys. There are many more, these are just examples.Comment
he told me that deans have the lowest resistence on the market and the bullets would just melt together and create a bomb. Its only a 60 amp esc and i am running 100c maxamps and an m445 is this just too many amps for the esc to handle? Are the batteries too powerful? Prop too big? It seems to me that based on what he said that i would either need batteries with a lower c rating or bigger esc...i am scared because i dont want to have the batteries explode from the connectors melting..... He told me that the people on the forums dont know what they are talking about. he also said that no one has problems with the spartan with the traxxas plugs..... could this because it has a bigger esc?. The guy seems like a real joke IMHO. As soon as you change your plugs to 5.5mm bullets and get rid of the deans your issue will disappear. Theres are reason why no one here uses those connectors and your seeing the reason first hand. You don't need a bigger esc nothing is wrong with your setup, the deans are the issue. Don't let that moron talk you into anything, its obvious hes not boat savvy. The truth of the matter is this, I do boating, fly and have land vehicles. Boating is by far in a league of it's own, everything that works in the other 2 will surely fail in a boat! The amp draw is simply unmatched by the other 2.
*Make sure you run your boat with wide open throttle as much as possible, don't cruise around at 1/2 or 3/4 throttle. In a plane and car thats fine, do that in boat and get the marshmallows out cause your esc is gonnaComment
alright i ran it again today and the deans were at 145 degrees... i think my temperature gauge misread it when it said 170.....is that too hot, should i still upgrade to 5.5mm bullets? thanks for all the answers and quick repliesComment
Sent from my T-Mobile G2 using TapatalkComment
i got the guy to do them today but he was still a little hesitant. He said it was because the esc wire is too small (14ga). Its the stock esc, and i am wondering if you guys did it on the stock esc as well. Just want to make sure that i didnt do something wrong....Comment
I'll chime in and repeat what others have said... ditch the Dean's connectors AND the hobby shop guy's advice. You're in good hands here with advice from folks that have run boats for a long time. And if by chance some noob here gives you some bum advice, someone will jump in immediately to give you the straight scoop.
You'll soon find that the great folks on this forum will give you good advice and do anything they can to insure you'll enjoy the fast electric RC boating hobby!
Take it easy,
desmobobComment
