How to remove prop?
  • EricRC
    • Sep 2021
    • 2
    How to remove prop?
    Hi people, sorry to ask a presumably stupid question but I am having difficulty removing the single propeller on a ABC hobby super hawaii. It's the stock one and it has alittle damage to it. I've seen online there should be a nut at the end, but in this case it looks like a long metal piece with two indentations in the side that don't appear to be screw either and then a cylinder in the middle sticking out just slightly. Any help would be appricisted! Also which propeller should I get as a replacement? It just doesn't seem to be shooting up the same rooster tail with the propeller this way.
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7119
    Please post foto, so we can help.
    There is probably a set screw hidden somewhere.
    "Look good doin' it"
    See the fleet
    • dasboata
      • Dec 2010
      • 3152
      Take the back of a screw driver handle and smack the shaft straight in ,,you should now see a gap between the drive dog and the hub you can gently pry that off now
