3 blade 1.4 pitch prop
  • meangenesracing
    • Jun 2012
    • 1158
    looking for a prop a little bigger than an octra 440/3 I see the next size up in the octra line is 447/3 and I'm sure is to big for my p hydro whiplash. I use the 447/3 on my 1/8 scale with great results. Any and all help would be appreciated thanks
  • fweasel
    master of some
    • Jul 2016
    • 4279
    ABC makes a 1616, which is essentially a 40.6mm diameter, 1.6 pitch ratio. Nothing from Octura in that size, unless you had a 447/3 cut way down, but those are hard to come by to begin with.
    Vac-U-Tug Jr (13mph)
    • koen
      • Mar 2020
      • 357
      Look at Modelbaucentre lorenz they have a ABC 1715 3blade and a lot of ABC props
      • dasboata
        • Dec 2010
        • 3152
        I have 1614/15/60/3 a bit bigger Jeano
        • dasboata
          • Dec 2010
          • 3152
          you better double check that ?
          • meangenesracing
            • Jun 2012
            • 1158
            Chris, whats the diameter of that prop? Is it a 1.4 or 1.6 pitch? How much, $ thanks
            • dasboata
              • Dec 2010
              • 3152
              1.6 diameter 1.4 pitch ratio $70 plus the shipping
              • meangenesracing
                • Jun 2012
                • 1158
                My calculations is only .03" bigger than what I have the octra x440/3 don't think that would make a very big difference. What you think?
                • koen
                  • Mar 2020
                  • 357
                  modelbaucenterlorenz.de in Berlin
                  • fweasel
                    master of some
                    • Jul 2016
                    • 4279
                    the 40.6mm diameter and same pitch ratio are not the numbers that matter here. The ABC props have more rake on the blades than the Octura props, which equates to more thrust. It also changes other characteristics like the amount of lift they produce at the transom of the hull.
                    • meangenesracing
                      • Jun 2012
                      • 1158
                      Thanks for the information I'm not that familiar with ABC props and props in general
                      • meangenesracing
                        • Jun 2012
                        • 1158
                        Chris, I pm'ed you on prop payment
