Prop bore diameter !
Using a 1/4 drive dog is a brilliant idea.
This puts all the stress on the outer diameter, and is not transferred through the step down.
I can't say for sure, but I'm willing to bet that the step down has a square corners at the step, which will lead to stress concentrations.
Going with the 1/4 drive dog eliminates all of that. That would be a much more robust setup.MYSTIC 138 119 MPH so farComment
After all the advice from very experienced people, those who have tried and also from dasboata, the prop guru, it's not advisable to do it. . . then perhaps he needs to find out for himself and go ahead and do it. . .Maybe he will be successful and we can all learn something new!. . .It's like telling a driver not to go through a red light as you might get caught and get a ticket . . .even worse get into an accident. So the driver does it a couple of times and gets away with it, finally on the third time he goes through the red light he gets hit by another car. . .the results are devastating, not just a ticket but perhaps lives lost. I apologize for the very harsh analogy but same principle.. .take the advice and save yourself the trouble. I too have tried it with no success as I ruined the prop before I could even put it on and break it during use. ..MYSTIC 138 119 MPH so farComment
Going with the 1/4 drive dog eliminates all of that. That would be a much more robust setup.Comment
[QUOTE=dasboata;733996]I don't know the specs on ABC props I don't have a chart on them my ESC was Luke warm with a X57 108 mph !MYSTIC 138 119 MPH so farComment
If you just have to use 1/4” cable, get one with a steped-down stub shaft. I would NOT drill out a prop, especially for high rpm SAW-type running.
https://www.offshoreelectrics.com/pr...?prod=ose-1290
It will not work with my drives
Mine , my bearings are at about 2 and 5 and it's 8mm thick shaft.
OSE , 3/16 to 1/4
ose-1290_shaft.jpgLast edited by Speedfreek; 03-30-2019, 06:59 PM.MYSTIC 138 119 MPH so farComment
