Prop bore diameter !
  • Speedfreek
    • Apr 2018
    • 276
    Just asking if you go from a 3/16 bore prop octura and open it up to 1/4, in a saw type setup would it still be strong enough?
    has anyone done this ?
    MYSTIC 138 119 MPH so far
  • larryrose11
    • Jun 2010
    • 757
    I would think you would weaken the prop hub substantially, and introduce all sorts of balance issues.
    0.187 flex is plenty strong, Especially the welded ones from Wholt RC.
    rc raceboat racing parts custom made for the racer.
    • dasboata
      • Dec 2010
      • 3152
      very very hard material to cut,,,with what equipment I have ,,, I will not do it for customers I'have ruined a few props that way
        If you just have to use 1/4” cable, get one with a steped-down stub shaft. I would NOT drill out a prop, especially for high rpm SAW-type running.
        https://www.offshoreelectrics.com/pr...?prod=ose-1290
        • Speedfreek
          • Apr 2018
          • 276
          HMmmmmmm.......
          • Speedfreek
            • Apr 2018
            • 276
            I tried this and the end snapped off
            But not with the OSE as per link you supplied, thanks
            • Speedfreek
              • Apr 2018
              • 276
              But if possible, would the hub be ok ?
              • Speedfreek
                • Apr 2018
                • 276
                http://www.rcraceboat.com/
                Thanks for your input
                • Doug Smock
                  Moderator
                  • 5272
                  Been there done that..
                  Did you put dog on the 3/16" stub? If so try it again and use a 1/4" dog.
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • Speedfreek
                    • Apr 2018
                    • 276
                    Not quite sure what you mean ?
                    Using a 1/4 stub now will not go back to 3/16 stub with my setup.
                    • Doug Smock
                      Moderator
                      • 5272
                      I was going by your post #6.
                      I have broken the stub off a step down cable using a 3/16"dog. If you decide to go with the cable Fluid linked to consider using a 1/4" dog. While it is still possible to break the stub off (although I haven't) it is less likely since you won't be removing material from the 3/16 portion of the stub for the flat for the dog.
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • Speedfreek
                        • Apr 2018
                        • 276
                        Yea that looks like a good shaft, i don't like the one piece one's that are machined down the two pieces ones appear stronger no weak point.
                        might need to get smaller ID bearings In my drives to run these.
                        The problem i have is that when i just want to have some fun and run a smaller prop there is no prop in 1/4 , and i don't trust 3/16 dog Any more with the torque these motors have.....
                        • dasboata
                          • Dec 2010
                          • 3152
                          Jay already told you no The hub would be to thin I don't suggest it at all what prop anyway ?
                          • Bp9145
                            • Jan 2016
                            • 1466
                            After all the advice from very experienced people, those who have tried and also from dasboata, the prop guru, it's not advisable to do it. . . then perhaps he needs to find out for himself and go ahead and do it. . .Maybe he will be successful and we can all learn something new!. . .It's like telling a driver not to go through a red light as you might get caught and get a ticket . . .even worse get into an accident. So the driver does it a couple of times and gets away with it, finally on the third time he goes through the red light he gets hit by another car. . .the results are devastating, not just a ticket but perhaps lives lost. I apologize for the very harsh analogy but same principle.. .take the advice and save yourself the trouble. I too have tried it with no success as I ruined the prop before I could even put it on and break it during use. ..
                            • larryrose11
                              • Jun 2010
                              • 757
                              Using a 1/4 drive dog is a brilliant idea.
                              This puts all the stress on the outer diameter, and is not transferred through the step down.
                              I can't say for sure, but I'm willing to bet that the step down has a square corners at the step, which will lead to stress concentrations.
                              Going with the 1/4 drive dog eliminates all of that. That would be a much more robust setup.
