Got some New abc props of interest in today
    Got a couple new release props in today. One very popular prop is the 1815, well and 1814 has been released with the same rake and blade area. Good for the setups with not quite enough power to turn the 1815. Then I got an 1814 three blade. 15 degree rake with a tad more blade area. I don't even know of a 45mm three blade so this one may fill a gap. It looks like it means business.
    • 9488
    Looking forward to the results of the 3 blade Travis
      • 7673
      PropShop has a 4514/3. I run it on the Pursuit, runs real well but now I may have something new to try.
      • dasboata
        • Dec 2010
        • 3152
        if a 1815 is 2 big the,,,, 1814/3 will be just as big because of it's 3rd blade the 3 blade props do have the advantages,, but your amps and load will go up ! best to reduce the 1815 and make that work then go to a 3 blade ! I do happen to like 3 blades better on a mono,, Keith does runs them with much success on his cats !
          I'm not quite sure what you mean by your post but it seems to me like your saying that I was implying that the three blade 1814 will be less? You may want to read the first post again. There is a TWO blade 1814 in the pic and what I was referring to.
          • dmitry100
            • Mar 2015
            • 1264
            dasboata: Any particular differences between 2 and 3 blade props? Especially on a cat...
              • 9488
              I try an run only 3 blade props on my Monos because they cause mine to handle so well
              love to find a 1515/3 blade
              need to try different ones on my Lucas Oil P Limited Cat next
                There is 1516-10-50(3)and a 1514-10-75(3) and a 1614-10-50(3)
                • dasboata
                  • Dec 2010
                  • 3152
                  Yes thats what I thought you were saying I did not realize the 2 blade was a 1814 ? my mistake Travis
                  • dasboata
                    • Dec 2010
                    • 3152
                    only the obvious,,, my personal preference is 2 blades on cats and 3 blades on monos but you can use them both on both !!
                    • dasboata
                      • Dec 2010
                      • 3152
                      I have 1614/3 and 1514/3 I can mod up ?
                        • 9488
                        Ok, educate me a little on these new 14 props
                        what do I loose or gain from the 1615 and 1715 props I have now ?
                        thanks
                        • dasboata
                          • Dec 2010
                          • 3152
                          Please PM me This is not my thread !! I can make the 1614 run just as good as the 1515 I was just offering you a alternative !
                            This is a public forum. We are all here to help each other (well at least some of us are) so I'm worried about being selfish with a thread I created. As long as my fellow members are being helped, that all I'm worried about.
                              • 9488
                              Agreed as you are both very helpful on this subject
                              I was wondering the difference between the 14 and 15 props
                              1614 vs 1615 example
