I would like to polish a couple of props but have a couple questions, I know u r supposed to use 600 grit wet sandpaper but, is that all? U just wetland till its shiny? any issues I may need to take into account, things to be aware of??
Prop polishing?
Tags: None
Stay off the trailing edge... Don't soften the sharp 90 degree edge.
You can carefully finish with a high-speed buffing wheel on a Dremel with a suitable wax-brick buffing compound.'89 Hydrostream Vegas XT w/ Mercury 2.4 Bridgeport EFI - 240hp - 95mph
ProBoat Blackjack 29 - 58mph, Traxxas Villain, Traxxas Slash 4x4, Align T-Rex 450pro, Blade mSR, Blade mCPx, Dynam Cessna 182, Blitzworks F/A-18, UM P-51, UM SU-26XP -
I'm probably gonna start on my stock proboat one, then my octura x642 then my newest m445 if in capable, ill upload pics so u can point me in the right directionComment
I used small sanding discs and soft abrasive wheels on my Dremel tool to do mine.'89 Hydrostream Vegas XT w/ Mercury 2.4 Bridgeport EFI - 240hp - 95mph
ProBoat Blackjack 29 - 58mph, Traxxas Villain, Traxxas Slash 4x4, Align T-Rex 450pro, Blade mSR, Blade mCPx, Dynam Cessna 182, Blitzworks F/A-18, UM P-51, UM SU-26XPComment
I'm not gonna use a Dremel, I'm using sandpaper, that works right? Do I NEED a mask when working with an octura prop, even though its gonna be submerged in water???Comment
I can't seem to get my pics uploaded from my phone right now, website isn't cooperating. I did one blade on the stock and might need a little more wetsanding but, want to know ur guys opinion, ill try and get some pics if I can get around the problemComment
I got one, if u guys need more I can try again in a little while, seems like its because I was trying to upload 2 at a timeAttached FilesComment
Question for people smarter than me..................
Most people scuff the bottom of the hull (make it a dull finish) so the water wont stick to it thus slowing the boat.
If water sticks to a shiny slick finish then why would you not want a polished prop ?
The prop is the wheel,gear,traction for the boat, so wouldn't you want a surface that grabbed the water ? (shiny)
T.C.Comment
T.C.Comment
