Prop polishing?
scuffing the bottom of the boat creates a thin layer of air pockets on the bottom of the boat. the boat is actually riding on air, not water, thus reducing friction/drag. the prop however needs the friction to move the boat forward, atleast on one side, the face of the blade. the back of the blade doesn't move the water. I polish the face of the blade and satin finish the back. this helps the face of the prop grab and move the water, the satin finish on the back side helps reduce drag and allows the prop to spool up.Comment
I don't mean to hijack the thread, just curious as to what the reasoning some have for not polishing ?
I would think a non polished surface would promote air bubbles and thus cavitation ?
I would also think any and every little speed trick you could think of would add up in the end ?
It's the whole combination not just one part that makes these run and the prop is a big part of the combo.
What do real boats do ?
T.C.Comment
My dads (real) boat prop is polished both sides. I think it's mainly all just preference and what u likeComment
In the "real world" of performance boats, the fastest props have a fine satin finish created by straight grit lines in the direction of water flow over the blade. Polished props are only for cosmetics.'89 Hydrostream Vegas XT w/ Mercury 2.4 Bridgeport EFI - 240hp - 95mph
ProBoat Blackjack 29 - 58mph, Traxxas Villain, Traxxas Slash 4x4, Align T-Rex 450pro, Blade mSR, Blade mCPx, Dynam Cessna 182, Blitzworks F/A-18, UM P-51, UM SU-26XPComment
Satin Finish
A sanded/satin finish causes water to stick to the surface of the object, the idea is that water on water is less resistance than a water to surface scenario, so effectively, having a sanded finish will cause a water on water planning effect, this should be the slickest way for any object to pass through water. Hope that makes sense.Comment
Skidbump your spot on re scuffed surfaces on hull bottoms, the scuffed surface allows a thin membrain of water to attach to the hull surface. So you end up with the water attached to the hull sliding over the lake water rather than a shinney surface of the hull which has more drag.Comment
scuffing the bottom of the boat creates a thin layer of air pockets on the bottom of the boat. the boat is actually riding on air, not water, thus reducing friction/drag. the prop however needs the friction to move the boat forward, atleast on one side, the face of the blade. the back of the blade doesn't move the water. I polish the face of the blade and satin finish the back. this helps the face of the prop grab and move the water, the satin finish on the back side helps reduce drag and allows the prop to spool up.My private off road rc track
https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8Comment
Indeed, you're reading it wrong. When someone talks about the "face" of the blade, it's the side of the blade that exerts force upon the water. The term "back side" of the blade refers to the low-pressure side which is facing forward, so the term can be confusing. Material is generally removed from the "back side", while preserving the shape of the "face."'89 Hydrostream Vegas XT w/ Mercury 2.4 Bridgeport EFI - 240hp - 95mph
that sounds counterproductive to me.......? Unless you were looking to widen the thrust cone.........My private off road rc track
so many theories ive heard over the years. ive tried polishing and not polishing without any noticeable difference between the two.Comment
Yes you would be better off spending the time doing something more productive on a boat else where than bothering with highly polished props, they do look nice but i wouldnt bother. Just making sure their nice & sharpened & balanced does me.Comment
