Ahhh dang I've heard the x series props create lift! Darn so the cnc props from offshore won't work! And I just ordered from hobbyking, and don't wanna pay expensive shipping for a while! Hahah looks like ill be rocking the octura m445 for a while then!! :/
CNC vs octura?
I didn't buy mine from OSE either, got them from Jan, his are made from T6061, or were when I got mine. Steve wasn't selling CNC props last summer, or at least I don't remember seeing any in his store.
I like the fact that they're balanced, and I'm going to have to respectfully disagree with you on the finishing part. Think about it for a minute, tuners always tell people to scuff up the bottom of their hulls, scotch brite, 400-wet/dry, etc., so why wouldn't you want to do the same to your prop?? Sorry guy, but I'm not understanding your logic
The Grim Racer prop guide I included a link to in post #9 states...
"We recommend a satin finish on the prop. A super shiny prop can cavatate more than a brushed satin finish. A satin finish can also help your boat accelerate out of a turn faster. Using a scratch pad, buff the entire prop down until all the shine is off the blades. Be careful as you are now working with a very sharp propeller."
Kinda figured Mikey has forgotten more about props than I'll ever learn, so I went with his advice.
Look at the tool / machining marks on the HK prop you included a link to (see attached), that's what I was referring to in post #9, those are what I'm trying to get rid of, I start with 220 wet/dry and work my way down to 400, I also work on taking out any dings on the leading edges, get 'em nice and sharp
JMHO / .02Comment
Ray,
JMHO / .02
Are OSE CNC props completely razor sharp from the package or not???
The Chinese ones I have worked o.k. from factory but, lit up very nicely after sharpening and scuffing. Easy to keep in balance by remembering how many swipes on 220 paper you do to get a fine edge. I still re-balance but, it's easy with aluminum.Nortavlag Bulc
I'm having good results with my CNC props from OSE.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
The ones I got from Jan have a sharp edge, but there is the occasional very minor ding here or there. I'm a perfectionist, figure if I'm going to invest the time to remove the machine / tooling marks, than I should also make sure the leading edges are as sharp as I can possibly make them.
Jan's are now precision machined from strong 7075 aluminum / magnesium hybrid (like Steve's) here's link in case your interested... http://kintecracing.com/CNC_Machined_Props.html
Regarding the odd ball bore sizes... I found instructions at Steves site (I attached them) for making spacers from brass tubing to fit 3/16" props to one of the odd sizes you listed, 4mm. What I do different.. make the spacer the full length of the prop hub and cut slots for the drive dog - see attached example.
Hope That Helps Out...Comment
Are these the ones your getting??... http://www.offshoreelectrics.com/pro...Props&sortby=3
Unfortunately, he's out of 42mm - so far that seems to be the size my boat like's most, but I do want to try a 43mm this summer, see what happens.Comment
Thank you. I didn't completely read your post the first time like I should have about the sharpness.
Ray,
Hope That Helps Out...Nortavlag Bulc
Has anyone tried these props? I looking for a good set of CNC'd L&R props for my twin 1515's
