drill out 3/16 props to 1/4"?
  • kevinpratt823
    • Aug 2012
    • 1361
    Has anybody tried drilling out 3/16 props for 1/4" shafts?
    My private off road rc track
  • h2o 1
    • Sep 2011
    • 770
    Why dont you just use a 1/4 shaft stepped down to 3/16. You can buy one here at OSE.Its nearly impossible to drill out a prop perfectly straight.
    • egneg
      • 4670
      I tried and it's fruitless.
      IMPBA 20481S D-12
      • 785boats
        Wet Track Racing
        • Nov 2008
        • 3169
        You'll need to chuck it in a lathe & ream it out to 1/4". But if there's not enough 'meat' left in the hub you could throw a blade at full noise. Not pretty.
        • kevinpratt823
          • Aug 2012
          • 1361
          I already got a reg 1/4" shaft, I'm going to use it with a couple 1/4" props I just ordered, and down the road may switch to a step down shaft if those props don't get me where I want to be. I figured somebody has already tried drilling them out and I just wanted to hear the results, pretty much what I expected.
          • keithbradley
            • 3663
            It's a pain in the butt, and it's almost impossible to get it perfectly straight.
            www.keithbradleyboats.com
            • twissted
              • Jul 2012
              • 867
              reverce rotation is need
              I looked to buy a set of 1/4 shafts with the step dwon and found that I can't find the right turn shaft. Where can I find counter rotating shafts with the step down. I have stainless props and they are much thinner in the shaft area. I think that I will have mine milled down and save me the trouble of looking.
              • highflyerbill
                • Jul 2011
                • 152
                What size motor are you using . Most good quality 3/16 flex shafts will take a ton of torque before you see any trouble .
                • kevinpratt823
                  • Aug 2012
                  • 1361
                  Mine is a DF Sniper 45" with a Castle 2028.
                  • carlcisneros
                    • Jan 2010
                    • 1218
                    he means the reverse rotating flex shafts.
                    • twissted
                      • Jul 2012
                      • 867
                      the motors are Hor racing SSS5694 1200 kv on 6s and also 8s twin. And the props are the Prop Shop 5517/3 stainless props.
                      • dasboata
                        • Dec 2010
                        • 3152
                        I might have the stepped down 3/16 rev shafts e mail me and I will look [email protected] thanks chris PS I have some 5517/3 SS props in 1/4" in stock !
                        • twissted
                          • Jul 2012
                          • 867
                          Well that is something that I wished I would have known before I had made the buy on ebay. I had a friend turn down my shafts to 3/16 to make my props work. he is a good friend so he only charged me 5.00. Coffee money. I meet with him in the mornings for coffee when I can.
                          I worked the props quite abit. I removed almost half of the metal from the back side of the blades. I like stainless for this reason. I order the 3/16 drive dogs and have the props to balance still. but there coming along. I will keep you in mine for my next props though. Thx!
