Has anybody tried drilling out 3/16 props for 1/4" shafts?
drill out 3/16 props to 1/4"?
My private off road rc track
https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8Tags: None -
You'll need to chuck it in a lathe & ream it out to 1/4". But if there's not enough 'meat' left in the hub you could throw a blade at full noise. Not pretty.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
I already got a reg 1/4" shaft, I'm going to use it with a couple 1/4" props I just ordered, and down the road may switch to a step down shaft if those props don't get me where I want to be. I figured somebody has already tried drilling them out and I just wanted to hear the results, pretty much what I expected.My private off road rc track
https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8Comment
I already got a reg 1/4" shaft, I'm going to use it with a couple 1/4" props I just ordered, and down the road may switch to a step down shaft if those props don't get me where I want to be. I figured somebody has already tried drilling them out and I just wanted to hear the results, pretty much what I expected.Comment
reverce rotation is need
I looked to buy a set of 1/4 shafts with the step dwon and found that I can't find the right turn shaft. Where can I find counter rotating shafts with the step down. I have stainless props and they are much thinner in the shaft area. I think that I will have mine milled down and save me the trouble of looking.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
What size motor are you using . Most good quality 3/16 flex shafts will take a ton of torque before you see any trouble .Comment
I might have the stepped down 3/16 rev shafts e mail me and I will look dasboata@aol.com thanks chris PS I have some 5517/3 SS props in 1/4" in stock !Comment
Well that is something that I wished I would have known before I had made the buy on ebay. I had a friend turn down my shafts to 3/16 to make my props work. he is a good friend so he only charged me 5.00. Coffee money. I meet with him in the mornings for coffee when I can.
I worked the props quite abit. I removed almost half of the metal from the back side of the blades. I like stainless for this reason. I order the 3/16 drive dogs and have the props to balance still. but there coming along. I will keep you in mine for my next props though. Thx!twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
