Prather Props
  • jfrancisco892
    • Feb 2012
    • 546
    Prather Props
    I was thinking about getting a prather s-220. I found a site called rocket city racing and they have prather props in stainless steel and bronze. What is the difference in performance or anything for that matter?
  • dana
    Banned
    • Mar 2010
    • 3573
    I think that stainless is stronger but much harder to work with. Not sure tho
    • ray schrauwen
      • 9475
      Yes, harder to work but a bench grinder works and no super toxic dust. No pic but I'm grinding down a x455/3 Stainless to 43mm, just because you need to play and it was cheap.
      Nortavlag Bulc
      • 785boats
        Wet Track Racing
        • Nov 2008
        • 3169
        I run a few Prather props & although the Stainless is a bit harder, a good set of files makes it easy. Plus they are already much thinner & better balanced than the Octura props so they don't take as much work to dress them up.
        • bikergreen
          • Jul 2012
          • 422
          I am prepping an S220 right now, any tips for the final steps to get a mirror finish? also there is some small pitting on the front/pitch side of the blades, I wasn't going to touch that side but is there a way to get those out without changing pitch to much?
          • jfrancisco892
            • Feb 2012
            • 546
            A fine abrasive like a scotch brite pad or emery cloth would probably do the job on the pitting. Just don't go crazy and you should not change the pitch.
