Dynamic high speed balancing services
Now the hard part is to get the tip in the center. Very hard to do by hand let us all know what you do to get it centered. Someone on here has shafts already ground I was looking for him as I want to buy a few 3/16 and one 1/4 for someday LOL I tried searching and he even said he made 3000 pcs to get the price down. I guess I used the wrong search words.
MikeDo It Like You Mean It .....or Don't BotherComment
Thats another way to do it. There are some very good people that can do up props. Some of us guy's just like rubbing, tweaking, bending not just props but everything LOL
THANKS ALOT MIKE!!!! now my wife wants to know where you live ..LOL..........i think thats what i am going to do is just buy them balanced ...less i can get this balancer fixed.. i just bought it knew one would think it should work with out pi$$ing people off...LOL....Comment
Ah you'll get it done now easy. Tell the wife North Side of Chicago with my cutie wife of 44 years. Well that is one of the problems with Hobby's and everything else. If it's cheap you get what you pay for! Good stuff costs good money and great stuff cost stupid money. So after many years I just set an amount to spend each year on my hobby. So good luck.
MCDo It Like You Mean It .....or Don't BotherComment
I was able to dynamic balance on my new magnetic balancer . I found that the blades were of even thickness yet the hub was heavy one side. So I used my center drill to remove some material. Worked like a charm . Now it rotates and stops randomly instead of the same spot.
I'm sure is not as accurate as what schenck is doing but good enough for me .42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
While we're at it, a few of my indispensable prop tools :
For thinning : (been posted before, but a favorite)
To insure equal blade length after reducing diameter
Super Hi-Tech Cupping Anvil **
** Super Hi-Tech Cupping Anvil can be found at local Thrift Store for $2 - $5 (comes with free corner lamp)
DSC04805.JPG2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
[ATTACH=CONFIG]104348[/ATTACH]
[ATTACH=CONFIG]104349[/ATTACH]
[ATTACH=CONFIG]104353[/ATTACH]
[ATTACH=CONFIG]104359[/ATTACH]Comment
I may be missing the point ( happens to me a lot) but going to great lengths to achieve optimum balance, statically and/or dynamically and then mounting it up linked to what usually is an out-of-balance drive dog makes me wonder. This has been addressed before and the answer seemed to be that the entire drive line needs to be balanced as a unit before maximum results are achieved. If anything, since this thread is about props only, and the prop/drive dog mate up as one, I'd think balancing the prop/drive dog together makes sense. Just sayin'..........
If you were turning your prop 1,500 RPM, it wouldn't make much difference. But you're not. You're looking more for the 15,000 to 20,000 RPM range.Comment
How true your statements are about complete balancing. I decided to make my own shafts that have the drive dog and shaft all one piece. I can match props to these shafts and use a bullet nut or clinch nut and balance it all as one unit. Then I can attach flex line, loc-tite it. The tolerances are key to attaching flex shaft. I cannot see how I could balance the shaft with flex, if someone can figure that one out,,,,,,,, but this is what I have come closest to a completely balanced driveline. I don't have any other pics, the pic was just the first ones made and some refining has been done. Plus they were stainless and I later found out they were not strong enough so new ones made out of tool steel and will be hardened and ground instead of lathed. I only have needed this or a saw set up 100mph+ cat in excess of 12,000 watts running almost 50k rpm.Attached FilesComment
48k+ in water under loadAttached FilesComment
