I just ordered the m445 prop for my new boat I am building. I need some info on a easy to use balancer thats recommended.
Prop m445
Tags: None
Esoteric.
Right here on OSE is a good place. Here's a link to it in Steve's shop.
http://www.offshoreelectrics.com/pro...-80310&cat=123See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
i like the topflight one cause it is a only 20 bucks, but there is a magnetic one that comes with different size shafts, 1/8th, 3/16th, 1/4 for use with different prop hub bores and is what i would get , if i didn't already have the topflight one. The topflight uses a single shaft with tapered "slide nuts" i'll call them which have a tendency to wear.
I would really like to get a 3/16 shaft for the topflight, but never had success trying to make my own and i couldn't tell ya how to get one.Comment
Hyperformance make a gd mag one with the different rods for the shaft sizes also here on ode store they have something similar.Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180Comment
