Right props 44" mystic??
  • Pwb201
    • 214
    I currently own 442's 447's but am looking for a good 3 blade to add into my collection.. Any suggestions?
    Also where to buy thanx everyone!
  • battlefury
    • Sep 2010
    • 256
    fightercatracing.com
    http://www.youtube.com/user/f4agusta09?feature=mhee
    • Pwb201
      • 214
      The smallest size I see is 50mm? I have a set of those as well and think they might be too big, looking for a little smaller but thnx
      • battlefury
        • Sep 2010
        • 256
        How about abc props from uk? They have a wide variety of props available
        • LarrysDrifter
          Big Booty Daddy
          • May 2010
          • 3278
          What motors do you have? Voltage? Top speed runs, or sport running? If you want more props just to own more props:
          http://www.offshoreelectrics.com/pro...0-50%283%29CLL
          • Pwb201
            • 214
            2 Scorpion 3026,2300kv 200amp esc's will run 4,5,and 6cell lipos depending on props
            Like I stated up top Larry looking for a pair not a single... Want to lift the rear of boat up for top speed runs hence 3 blades, not looking "more props just to own".
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3278
              You can get them in left and right rotation. Nobody can suggest any prop at all with out knowing what voltage will be run. If youre running different voltages, then use the 442's for 6s. Try either the 447 or ABC's on 4 and 5s. It does help to be specific with your set up and intended use of the boat.
              • LarrysDrifter
                Big Booty Daddy
                • May 2010
                • 3278
                Heres the right hand
                http://www.offshoreelectrics.com/pro...0-50%283%29CLR
                Since OSE is out of them, www.rocketcityracing.com may have them in stock. If they are out, just look around. Maybe pm Dasboata or email him, as he might stock some props.
                • Pwb201
                  • 214
                  Thanks Larry
