2 Scorpion 3026,2300kv 200amp esc's will run 4,5,and 6cell lipos depending on props
Like I stated up top Larry looking for a pair not a single... Want to lift the rear of boat up for top speed runs hence 3 blades, not looking "more props just to own".
You can get them in left and right rotation. Nobody can suggest any prop at all with out knowing what voltage will be run. If youre running different voltages, then use the 442's for 6s. Try either the 447 or ABC's on 4 and 5s. It does help to be specific with your set up and intended use of the boat.
