Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 which props?? - Offshore Electrics Forums
which props??
  • launchpad
    • 194
    which props??
    I need some suggestions on what props I can use. The specifics are as follows.Genesis Rc Boat 38" cat;2x3674-2700kv;2x125amp hk esc,2x5200mah 4 cell 45c lipo.and a ubec.I do not know how to calculate it to get the best ones.This is my first dual motor rc boat that I built.
    Any help will be greatly appreciate it. Have A Good One
  • Make-a-Wake
    FE Rules!
    • 5557
    If you have counter rotational props, which would be best, try out the Octura x442 L + R's.............but i would only run it on 3 cells each.......
    http://www.offshoreelectrics.com/pro...prod=oct-x442r
    batts - http://www.hobbyking.com/hobbyking/s..._3S1P_40C.html
    • launchpad
      • 194
      which props
      Thankyou for the info,are the props metal or......What would happen if I decided to run 4 cell batteries.Would something fry or melt.I will be ordering those props from Steven at OSE. Thanks Again
      AL
      • Make-a-Wake
        FE Rules!
        • 5557
        4s may put you over the safe zone for the ESC's.............. If you have to go 4s then cut these down to around 38-39mm..............my opinion of course, lets see who else chimes in. 2700 kv is right in the 3s zone for a motor, what brand motor is it by the way..........and 2 pole or 4 pole?
        PS, you running counter rotating?.............oh, and these are berylium
        • launchpad
          • 194
          which props
          Forgot to tell you the make of motors.They are the FSD motors.Guess I will see how could they are.If they blow ,then I will get 2 leopard 4074.I will more than likely get the 3 cells start from there. Have a good one
