Rotational speed for magnetic prop balancing
  • detox
    • Jun 2008
    • 2318
    All of that fancy balancing means nothing if you have lots of harmful harmonics going on inside stuffing tube. Other than balancing, what is the trick for quiet resonate free spinning.
    • HOTWATER
      • Nov 2008
      • 2323
      Once you have cut a flat spot on the motor shaft, you have lost balance....where do we go from there....??
      "Will race for cookies!"
      IMPBA D12
      My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
      • properchopper
        rcgoatbuild@snotmail.com
        • 6968
        Keith, I'm not claiming to be too knowlegdeable on this topic/situation but I'm going to make a somewhat educated assumption that the resonance/harmonics are in large part created by driveline imbalance coupled with loose tolerances. Tackling/curing these conditions may be the answer. My first Drifter had a major resonance that had me trying everything you could imagine, like lining the hull with Dynamat and greasing the heck out of the shaft. The current owner still has this situation which can be temporarily handled by using gobs of thick marine grease on the flex cable, but as it heats up and thins out it returns. My current Drifter is lined with CF and uses a wire drive, with no real vibration/resonance. I'm guessing that the wire drive/collet is better balanced, although my prop balancing skills leave a lot to be desired.
        • properchopper
          • 6968
          I recently was provided with several samples of a stainless drive dog to test. Gave one to Jay,Brian & Darin to try out. Just put it on the balancer & it balanced as perfect as it could be right out of the "box" . Octura's lately have been drilled out too much causing a tiny wobble BTW.
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            Are the stainless dogs from Octura?
            • properchopper
              • 6968
              Larry, Not Octura. Uncool for me to promote competitors to OSE, so I "kint" say where they're from [they're now available]
              • m4a1usr
                Fast Electric Addict
                • 2038
                None of us can change harmonics related to rotational imbalances unless we specificaly target each part of the rotating items. You tackle the prop, so next you move onto the other components. But we cant spin each particular compontent to make the necessary imbalance adjustments to improve that particular or specific issue. The reason is due to one of the very common issues we deal with. We allow for "slack" in our drive lines. The gap we allow on the azz end is our weakness. Harmonics have a range of influence over the operating rpm range. You might have a 1st order at 5k, a second at 12k and a 3rd or 5th higher. Your never going to correct those issues unless you reduce imbalance at every possible avenue. Hopefully you minimize it to a level that is at best described as adequate. But with slack in the driveline we do the one thing verbooten in propulsion systems. So we suffer imperfection. I dont have the answer to making it perfect. We tackle it were known weakness is expected. Not picking on you but choices have to be made and rotational mass should be the one getting the attention first.
                John
                Change is the one Constant
                • dasboata
                  • Dec 2010
                  • 3152
                  #23
                  Apples and Oranges,,, That is a balancer designed with a motor to pick up Vibration much like a Hi Speed tire balancer, that looks very interesting. But the guys here spinning props on a Magnetic balancer are just wasting there time !! And PS not to pick on you Properchopper I know your a old NY guy but you have a heavy blade there in your video !! Send me that prop I will do it for free for you !!! And then you can put it back on a Vid
                  • Mike Caruso
                    • May 2012
                    • 940
                    #24
                    Or a window fan across the room can create an interesting phenomenon :
                    http://www.youtube.com/watch?v=Qa_psjdj7XU
                    That's plenty of rpm AND YOU STAY COOL AT THE SAME TIME.
                    Finger speed is plenty don't over think it. Use clay on the light side so you can see where you need to remove weight 180 from the light spot.
                    Do It Like You Mean It .....or Don't Bother
                    • Mike Caruso
                      • May 2012
                      • 940
                      #25
                      John
                      Hi John,
                      Sorry I did not see your reply's above.
                      You know my friend very cool setup. People have no idea how much good you can do with a balancer. I can still see the strobe light and the part moving through the critical rpm. No computer read out for the heavy position back in the 70's ha wish I did have it.
                      Mike
                      • properchopper
                        • 6968
                        #26
                        Mark and I, not twenty minutes ago, were discussing some SAW setup details, and both agreed that wire drives eliminate a bunch of resonance. The resonance is noise, and noise is energy better used for propulsion. My SAW Drifter S record holder with a wire drive is quite resonance free, so much so that the sound of the prop beating on the water's surface is highly audible. Jeff Wholt wire & coupler, btw.
                        • HOTWATER
                          • Nov 2008
                          • 2323
                          #27
                          Tony, what size boat ,power and what size wire are you using...I have an .078 from jeff that I have yet to use...just curious...I have an ML hydro that I am still thinking about as far as what I will be using for a drive line....was wondering the same thing about the wire being truer than a flex.....giddyup!!!
                          IMPBA D12
                          • properchopper
                            • 6968
                            #28
                            I use a .078 in the Drifter S (26") with UL-1 power on 4S. Mark does the same on his FE30 for spec and P-Sport. USE AS LITTLE BEND AS POSSIBLE.
                            Here's what an out of balance flex driveline setup sounds like [ yellow boat at 2:05 ; 2:26 ; 2:56 seconds ]
                            Here's my Drifter {UL-1 motor/4S} with the wire drive
                            • TheShaughnessy
                              • 1431
                              #29
                              tony are you using ball bearings, lead teflon or brass bushing?
                              • properchopper
                                • 6968
                                #30
                                I've found that ball bearings have a short lifespan in marine applications. I prefer L/T but I use both L/T & brass depending on the boat.
