Tenshock props as Aflfa posted. I had got some from MINICAT as the owner is a member of our club. pretty nice props. Mine went to the bottom testing one of Fightercats boats for him. He just sent me a few more. I will run them again. If youv seen my DF cat single drive maiden vid in the vids section, it was running the 42mm Tenshock.
CNC prop's
hey Alfa;
These props you show,are they for your genesis,will they fit,also,is one left and the other right?So far I have installed the power trims on my genesis.The motor mounts are in and getting ready to install the motors.Installing them will be difficult as there is no room to get your fingers or allen wrenchs in there.I have also layed kavlar on the tunnel and now waiting for the battery tray from Fightercat racing.I used the former battery trays for the esc mounts.They will be laying behind the motors on top of the battery trays and in the sponsons. There are some photos on the build in my gallery.Any input would be helpful.Comment
I don't see why the right machined aluminum alloy wouldn't work. See:
7075 aluminum http://asm.matweb.com/search/Specifi...ssnum=MA7075T6
Berylium copper as cast http://www.matweb.com/search/datashe...da2678b61257ac
Berylium copper age hardened http://www.matweb.com/search/datashe...b9e6792&ckck=1
I've worked with 7075 aluminum. It machines easily and is very strong. Bending it is like bending any hard material; it's hard to bend and cracks easily. That means you can't modify the props by bending and then harden them like the as cast bronze props.
Lohring Miller
Just my .02FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Yes, Tenshock props are ok for the Genesis twin, I' ve got an order for a set of 42mm 3 bladesAttached FilesComment
