CNC prop's
  • lohring
    • Jun 2011
    • 183
    I don't see why the right machined aluminum alloy wouldn't work. See:
    7075 aluminum http://asm.matweb.com/search/Specifi...ssnum=MA7075T6
    Berylium copper as cast http://www.matweb.com/search/datashe...da2678b61257ac
    Berylium copper age hardened http://www.matweb.com/search/datashe...b9e6792&ckck=1
    I've worked with 7075 aluminum. It machines easily and is very strong. Bending it is like bending any hard material; it's hard to bend and cracks easily. That means you can't modify the props by bending and then harden them like the as cast bronze props.
    Lohring Miller
    • dasboata
      • Dec 2010
      • 3152
      well I don't see the fastest boats in the world running aluminium props, SS is the prefered material,,, and it is for a good reason,,, it is stronger and can be made thinner,, and any Boat that comes from the factory with a alum prop, is for the most part replaced with a SS prop up grade
      • lohring
        • Jun 2011
        • 183
        I believe Joerg's 140 mph hydro ran a prop cast by a dental lab. if so, that material was a cobalt chrome alloy, not stainless steel, an iron alloy with chromium, nickel, and other alloying elements. Stainless steels aren't as corrosion resistant. Both have similar strength, close to twice that of 7075 aluminum.
        Lohring Miller
        • ray schrauwen
          • 9475
          All the R2 hobbies cnc props come in 4mm bore. They are very nice, top notch machining. I did order one set to my benefit they came in 3/16" bore!!
          I ordered one more after and I got 4mm bore...
          The HK 32mm & 35mm 3blade props are also beautiful, even nicer than R2 hobbies. These two come in a bit sloppy 1/8" bore.
          Thats all I know...
          Nortavlag Bulc
          • Boaterguy
            • 1760
            were the HK ones centered on the shaft? I'd be surprised if every one came out perfectly centered, especially from HK.
            • netik racing
              • Jan 2010
              • 60
              so if i was to be able to get some SS prop made what would be a price that people would pay for them....??????
              HOTR 32" Neu 1515 112 kph / Etti Demon rigger 3s leopard motor / 36" r2 hobbies twin tunnel with leopard 2200kv / Delta force 22 Hydro with dirty 2 pole motor / mini bolt with 380l motor good for about 60 kph
              • Grazacind
                • Jan 2011
                • 328
                Originally posted by egneg
                A while back Meniscus sent me an email with a link to props in the UK unfortunately that PC is dead. They were very nice ready to go but a bit pricey at over $50.00 usd shipped. Hopefully he will see this thread and provide a link.
                Link to the prop shop. http://www.prop-shop.co.uk/
                Andrew
                Find it + Buy it + Twin it + Run it = WOOHOO
                • martin
                  • 2887
                  #23
                  Astec Models in the UK has the Etti cnc props, You can also get them from Etti HK on Ebay as well.
                  • egneg
                    • 4670
                    #24
                    They were not Prop Shop ... I wish I could remember what they were.
                    IMPBA 20481S D-12
                    • martno1fan
                      Banned
                      • Jan 2011
                      • 238
                      #25
                      You can get cnc props here,email him for other sizes and his prices are good too.
                      • jj2003
                        HIGH VOLTAGE ADDICT!
                        • May 2011
                        • 1501
                        #26
                        who is selling them?
                        Ben is selling them. Find them here;
                        I beleive they are tenshock but not 100% sure.
                        "If guns cause crime, all of mine are defective"
                        45"Speedfreek
                        , Fightercat #068 ​, MyYoutube Vids
                        • Peter Duggan
                          • May 2008
                          • 14
                          #27
                          Cobalt Chrome is the best metal available for Model Boat Propellers but I guess I am a bit biased.
                          Peter
                          EB Taipan Schulze 32/200 1527 1d. 4s 5000 115kph
                          CoCr Racing Propellors
                          http://cocrracing.com.au
                          • Alfa Spirit
                            • 2131
                            #28
                            I use those props, they are ready to run. For DD 3/16, pitch = 1,42
                            Those props are light, not strong like Octura and Prather props
                            • Gimp
                              I am the Stig
                              • Jan 2011
                              • 547
                              #29
                              Anybody else using Ben's FC CNC props?
                              -Fighter Cat Racing-
                              • monojeff
                                Moderator
                                • Nov 2010
                                • 2562
                                #30
                                I have one I will be testing on my elam figured it was another good option compared to the CF props out there.
                                The one I have is the 443 and if runs well will probably get some of the larger ones from him.
                                Will not be able to test for a few weeks as I am working on the boat getting it RTR.
                                OSE GIFTING ELF
                                HAPPY HOLIDAYS!!
