Who wants to build a semi-scale all-wood micro hydro?
  • Dr. Jet
    • Sep 2007
    • 1707
    #196
    Went to the Pond Today
    And carefully video recorded everything on my spy glasses. I got home, pulled out the card and......
    NOTHING!
    Other than that, here's the report:
    I don't like the curved turn fin in the Atlas. If it's not perfectly oriented. it will either lift up or dig in the right sponson. I'm going to take the bend out of it for the next trials. I need to toy with CG and strut angle/depth, but it's really close. The atlas hauls buns on 2S with the Y531 plastic prop, and even does OK with the 27mm plastic prop (thinned and sharpened) in the kit. The motor was a bit warm at 125° with the Y531. I think the optimum prop would be a de-tongued X432 reduced in diameter to 30mm, Motor temps with the 27mm prop were slightly warm to the touch.
    It gets up on plane instantly with either prop I tested and corners like a dream, but it does bleed off some speed too. The 1/32 wire drive worked flawlessly and there wasn't a drop of water in the hull after running.
    All in all a success I would say.
    • old guy
      • Nov 2008
      • 687
      #197
      any up dates on the round nose
      • Dr. Jet
        • Sep 2007
        • 1707
        #198
        I will contact the laser guy tomorrow, Monday. I suspect he should be back and can get to it rather quickly. The kits are ready to go (except for the wood and instructions). I'll let everyone here know.
        • old guy
          • Nov 2008
          • 687
          #199
          hows your prototype coming along
          • Dr. Jet
            • Sep 2007
            • 1707
            #200
            I'm at a standstill because I need the sponson bottoms to proceed. I'll get them when the new stack of wood is cut. I've run the 1:16 scale roundnose and it drives great. The 1:16 and 1:20 Atlas drive virtually the same, so I expect the smaller roundnose to be pretty much the same as the larger version.
            Do you want to do yours up as the '58 Short Circuit or do you plan a different livery?
            • old guy
              • Nov 2008
              • 687
              #201
              i know it will not be 100% scale but was thinking one of the such crust boats but not sure yet
              • Dr. Jet
                • Sep 2007
                • 1707
                #202
                None of these are really 100% scale. They're more "Stand-Off Scale".
                This would do a convincing model of any of the single-engine Such Crust boats.
                Note sent to laser guy, waiting for response.
                • Dr. Jet
                  • Sep 2007
                  • 1707
                  #203
                  Just heard from the laser guy. He can start cutting the Roundnose and the rigger on Thursday; I may have stuff ready to go out on Friday!
                  UPDATE: The laser guy has the wood as of today, April 2, 2019.
                  • Dr. Jet
                    • Sep 2007
                    • 1707
                    #204
                    Originally posted by JimClark
                    Looks great very good detail. What about weight?
                    The DLP Merlin is a bit large and probably needs to be reduced by 15%. Furthermore, it is the entire engine, you will no doubt grind off the lower half (or more) to get it to fit in a hull. As such, it is 54 grams right now. The FDM one (and only the upper 50% of the engine) is 21 grams. My guess that a proper-sized DLP engine, cut down to the the visible components would be an ounce (28 grams) or less.
                    • Dr. Jet
                      • Sep 2007
                      • 1707
                      #205
                      I have four roundnose kits boxed up and ready to go.
                      I have four Atlas kits boxed up and ready to go.
                      • Dr. Jet
                        • Sep 2007
                        • 1707
                        #206
                        This project has languished for some time while I worked on other projects. As a result of my last outing on the pond, I decided to update my decades-old and slightly shrunken Jay Turner Pool Racer (JTPR), mainly because it was just too much fun. The new and improved Mini Pool Racer (MPR) #1 is complete and ready to go using the drive train salvaged from the original JTPR. MPR #2 is on hold waiting for parts to ship on a slow boat from China. See separate build thread here in "Mini and Micro Boats".
                        The shovelnose hull only needs the sponson non-trips, the flotation foam, and the decking to be complete enough to start sanding and painting. The Atlas needs a paint touch-up (I screwed up doing some sanding ), some final clear coating, and final assembly/detailing to be completed. The Atlas Prototype #1 has already run with a couple of cheap plastic props and while it was more than satisfactory with those, I think I've narrowed the final choices to an Octura X430 de-tongued, or an X632 reduced to 30mm and de-tongued. I may start with an X431P (plastic) that is de-tongued and reduced in diameter.
                        Due to operator error, my attempts to video it at the last outing failed . I plan to go to the pond on Saturday, May 11th and hopefully will video it with all of the aforementioned props.
                        • Dr. Jet
                          • Sep 2007
                          • 1707
                          #207
                          I'm About To Deck That Sucker......
                          • Dr. Jet
                            • Sep 2007
                            • 1707
                            #208
                            The Cowl
                            I received some questions about the making of the cowl. It's made from layers of 1/4" balsa stacked together. The cowl and the headrest (glued to the plywood fin) get sanded to shape before the fin/headrest assembly are glued to the cowl. Then, the headrest gets faired into the aft cowl with some putty/Spackle. After everything looks good, the bottom gets sanded to fit the deck.
                            • Dr. Jet
                              • Sep 2007
                              • 1707
                              #209
                              All Decked Out.......
                              .... And nowhere to go....
                              • old guy
                                • Nov 2008
                                • 687
                                #210
                                well the round nose made it to my sisters thanks I might see it by summers end lol so waiting for you to finish up yours so I can see what hardware is in the box and a video of it running lol
