2.3mm to .098 quality coupler, or 2040 motor w/ 3mm shaft?
  • Dashunde
    • Sep 2014
    • 53
    I just started messing with my new TFL Small Bolt.. first thing I did was to make sure the radio/esc/motor/servo all work, so I spun it up... it buzzes like crazy
    The 2.3 coupler kinda sucks with its wobbling.
    Is there a better 2.3mm-.098" coupler out there, or maybe a motor in this same class with a 3mm shaft?
  • NativePaul
    Greased Weasel
    • 2761
    Do you want a grub screw or collet type coupling? Evgeny at Ecomaster.torgg sells the grub screw type in 2.3mm-2.5mm, 2.5mm is 0.0984
    • Dashunde
      • Sep 2014
      • 53
      I guess this would be ideal as it wouldnt mess up/fray the cable end with a grub screw... but I dont see it in the correct 2.3mm - .098"/~2.5mm though.
      Its also way over in the UK..
      • NativePaul
        Greased Weasel
        • 2761
        That link goes to a grub screw one doesn't it? If so it is the tenth one on the drop down size menu. I thought he did collets too which is why I mentioned it, but when I checked his collets are not available in that size.
        Evgeny is in Ukraine, not UK. You don't have to buy it, but if you can't find it elsewhere, there is a quality part available.
        • Dashunde
          • Sep 2014
          • 53
          Ok, thanks, yea the link is to the collet style that isn't sold in 2.3x2.5
          The dual grub version is the TFL stock part, guess I'll see what I can do about balancing it a bit, maybe a ziptie will get some of the buzzing out..
          • ray schrauwen
            • 9475
            http://ecomaster.torgg.com/collectio...-grebnogo-vala
            Thank you! Those are nice and I could use one of those 2mm - .125"
            Nortavlag Bulc
            • Gromov
              • Aug 2012
              • 49
              Yes, dear gentlemens. This coupling and collets in stock...
              ecomaster.torgg.com
