It's easier to copy these days, change one thing and make it their own. Chinese are experts at copying and reselling even products from their own country and competitors. They copy and make it cheaper than the original, and make a profit and 90% of the time it's the same quality or better sometimes, and who benefits? We do. It is the right thing to do? Most consumers don't care, some do. You know how it works, all they have to do is change one little thing and they can market it, which if you look at both ESC the caps are different, everything else looks identical. It's the way of the world now.
Largest Motor/ESC Combo In JAE Mini Sprint
We benefit in one way, that we get a cheaper product now.
If lots of people buy the cheaper clone, the company that put money into R&D cant recoup that investment and afford to do more R&D, eventually they will go out of business, we lose because it stagnates the technology. Not only do those that buy the clones get older technology, but it slows down the advance of technology that is out there to be cloned.Paul Upton-Taylor, Greased Weasel Racing.Comment
Well, I ordered a Flycolor 70a too.. we'll see if its a better fit, hopefully its only ~17mm thick.
I should have just ordered the FE21.. probably would have been cheaper overall
The YGE copy thing is kind of interesting in that they're apparently "made in Germany", but to what extent and using parts from where?
YGE does not appear to be a very big outfit, at least from a product selection and minimal website perspective.. In reality their "property" and R&D may only amount to firmware?
For comparison, Castle receives boards from elsewhere then they pick-n-place everything in Olathe KS
An interesting read on Castle.Comment
I ordered the box that says Flycolor at the bottom/middle which is what is on their site also and will see if that works. I am also told the one from OSE may work as the Raider ESC is actually a Flycolor rebranded.Last edited by SweetAccord; 10-04-2016, 08:07 PM.Comment
Sweetaccord, I ordered the 70a... have no idea which box would work with it?
So I went to build and found all of my ca dried up - had a baby girl in 2012 and haven't built squat since and didnt check it ahead of time :/
While I'm waiting on a fresh batch of Mercury adhesives I've been looking it over, prepping parts, etc and I keep coming around to the same question...
Why is everyone reinforcing some variation of the stock plywood mount when the rudder in the kit comes with a "L" mount already?
The "L" mount is about .25" longer, but can easily be cut back and re-drilled for the same length as the original wood (leave the wood in place as a template, then cut it off later).
Is the weight a big deal? Seems that the required reinforcing adds a fair amount of weight anyway?
I'm thinking I'll just cut the L mount back a bit to keep the original length, drill a couple holes in it to reduce weight, and double-ply the transom with thin sheet cf.
Is there some aspect I'm not seeing yet that makes all of that a no-go rudder mounting method?Comment
Mine took a buoy strike to break it and a small diagonal reinforcement glued in held up even when it was all held together with glue. If I was to build another I would use lighter wood all round and add the diagonal from the start.Paul Upton-Taylor, Greased Weasel Racing.Comment
Don't see any reason why it won't work. After tearing out one of the holes on mine, I put in a piece of triangle stock and a thin plate of CF along the side of the tub. By the way, I don't know if you are just going to tack it together with CA and then epoxy it, but I would recommend going over all the joints with epoxy. This little thing is fast for it's size, and puts some serious loads on itself.
BobComment
Ok, L bracket it is then..
One main concern I have is if it hits something the brass screw will fail to sheer, instead ripping the hole out of the wood, that or just fumbling it during transport.
Bob, it'll depend on the part.. if it can be clamped in place, or is pure structure, I'll use epoxy. But superficial or ornery parts will get ca'd or a combination of both... a light/stingy epoxy application with a couple small spots left dry for a dab of ca/kicker to hold it while the epoxy dries. And I'll go over all of the joints with epoxy again followed up by finishing resin. I dont under-build anything, but I wont make big puddles in the corners either.
Building several planes has taught me the most important thing for a good bond is to lightly scuff away the laser-burnt edges.. nothing bonds well to charcoal.Comment
Do you thin the epoxy to get it to flow or wick better into the narrow gaps left after the part is ca'd into place?
This thing will bust up in a run-of-the-mill wipeout? I thought t was mostly the booms?
I wonder... I have some 1/16 and 3/32 carbon fiber sheet here... and a nice set of new plywood "templates".Comment
Yes, I CA'd in place and then added epoxy over the area and sanded off any hangs. The CA holds very well buy itself amazingly. I glued some seams (as a test) with CA with some left overs from the kit and when I broke the pieces, where it broke was around the area the CA was, not where the CA was. So that it good, but don't build it just with CA, just use to hold the pieces in place, and then lightly coat over the area with epoxy for full strength and then sand off any excess, as excess (thickness in height) does not help in any way if there is already a thin coating of epoxy between the seams. The epoxy gets into the wood pores and with a thin layer it's very strong but can still crack being a thin layer. It's a hit 22 type build.
Hope that helps.Last edited by SweetAccord; 10-11-2016, 02:59 PM.Comment
Ok I confirmed the Flycolor program box that works with the 90A ESC. It should also work with the other lower amp versions. Settings are 1-5 only.
These are the same settings as the OSE Raider and it's the same box: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The manual on OSE's site is a bad copy. Attached is a better clearer version.
Hope that helps.Attached FilesLast edited by SweetAccord; 10-12-2016, 04:02 PM.Comment
