Atomik barbwire prop and motor upgrade?
  • stadiumyamaha
    • 1284
    Sky lipos.
    I believe mine is the v2 with the two caps I it.
    white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
    • Yiming
      • May 2013
      • 44
      3000kv scorpion out runner on mine.... 3s with seaking35a stock prop zero timing
      The speed is .....good
      Motor temp is hot but acceptable ...
      Yiming
      Singapore
      • stadiumyamaha
        • 1284
        Anyone know how to program the stock esc ?
        • Yiming
          • May 2013
          • 44
          I don't see any one selling program card for that esc
          Yiming
          • bayareaheli
            • Jul 2014
            • 144
            little quick inrunner motor mount i hacked up for the barbwire bit sloppy lol, just need to drill 2 holes on each side will bolt directly to the stock moulded in stand offs of the hull, going to try and do a 3d printed one next.
            but just an idea if you dont want to hack up your hull
            best regards
            • ray schrauwen
              • 9475
              The stock prop is 30mm. I just fixed up a barbwire for my gf's nephew. I installed a S & B Octura 430 prop. Even though the shaft is only 3mm, when it butt's up against the drive dog and secured with prop nut, it runs balanced and square.
              I wonder how that scorpion motor is mounted in one of the above posts... #17 ???
              The stock battery needed to be destroyed since one or more cells went bad. Yes, it seems LVC is very conservative, safe but, it doesn't help cycle the pack well.
              Nortavlag Bulc
              • ray schrauwen
                • 9475
                Originally posted by Yiming
                [ATTACH=CONFIG]116589[/ATTACH][ATTACH=CONFIG]116589[/ATTACH]
                Yiming
                Singapore
                Try 15 degrees. Outrunners prefer higher timing.
                Nortavlag Bulc
                • Yiming
                  • May 2013
                  • 44
                  #23
                  Ray
                  Will try that next time ...the boat jst too small for that motor...
                  My thinking is lower the timing to get the possible lowes speed I can get without
                  Piss off my buddy....
                  • Yiming
                    • May 2013
                    • 44
                    #24
                    Ray
                    • ray schrauwen
                      • 9475
                      #25
                      Lower timing on an outrunner can add heat and not change much else.
                      Hard to tell if you bolted motor in with or without drilling holes in mount??
                      Ray
                      Nortavlag Bulc
                      • Yiming
                        • May 2013
                        • 44
                        #26
                        I make some grove with file left and right on the stock motor mount.
                        Do it carefully untill u can pass tru the bolts for the motor.
                        • microboatdude
                          • Jun 2014
                          • 25
                          #27
                          best regards
                          You get this working?
                          • bayareaheli
                            • Jul 2014
                            • 144
                            #28
                            here is my modded barbwire with cut down sharpened balanced and cupped 32's first test in video is with the 431 second part of the video is the 631 prop which launches the boat like crazy out the hole lol
                            • bayareaheli
                              • Jul 2014
                              • 144
                              #29
                              No haven't finished it yet will finish it up this week :) just need to drill some holes and mount it.
                              • f.a.r.m.e.r
                                • Apr 2015
                                • 63
                                #30
                                Here is my highly modified barbwire
