Esc help please
  • steve513
    • Apr 2012
    • 9
    Esc help please
    Hi, i recently got a hold of a joysway mini cat. I have a b2445 3000kv brushless motor i would like to install, would like someadvpce on what esc would work. I was thinking a 30 amp and 11.1v 2200 lipo. Im actually a big gas guy, so some advice on FE would be great. Also have a couple b2030/10-4300 motors, if there any better. Just hoping for some esc n battery advice with the motors i have. Thank you so much for your input....steve
  • lenny
    • Sep 2010
    • 4296
    Hi,
    I have a sea rider cat and a hydro mini bolt,
    They both came stock with ESC: Water cooled 30A w/BEC setup,
    Running 3s 25c 2200 mah cells.
    ? ONLY IF THEY WORK
    • steve513
      • Apr 2012
      • 9
      hi, thats the boat i have, r u running that battery on stock motor and stock esc? If so hows performance?
      • lenny
        • Sep 2010
        • 4296
        Yes, Stock Water cooled B2445 3000KV,
        The cat not bad, Runs better at high speeds and better handling their.
        I do not run it much to sit down and take the time and tweak yet,
        But the hydro bolt is tweaked and a runner with a y535 prop,
        And I made the hatch with a water tight seal and one thumb screw holding it on.
        ? ONLY IF THEY WORK
        • steve513
          • Apr 2012
          • 9
          very nice, but i do t see how to use stock esc with new motor, there wired together (solderd) not just plugged in to
          each other. Thinnking of new 30 amp esc, but not sure what (brand) dont want boat to go up in flames lol. What prop u have on the cat? Hope im making sense..
          • Make-a-Wake
            FE Rules!
            • 5554
            I'd get a 40a minimum if you can find one. I just ordered one of these and have a cooling plate I'm gonna throw on it.
            http://www.hobbyking.com/hobbyking/s...dProduct=24235
            • lenny
              • Sep 2010
              • 4296
              Can you solder and strip wire ?
              Their are three wires on motor and esc, When you put the wires together check for left hand rotation,
              And you should be good to go.
              Hears a link for a good esc's.http://www.hobbypartz.com/seaking.html
              Or put a WTB post up for one.
              ? ONLY IF THEY WORK
              • lenny
                • Sep 2010
                • 4296
                I'd get a 40a minimum if you can find one. I just ordered on of these and have a cooling plate I'm gonna throw on it.
                ? ONLY IF THEY WORK
                • steve513
                  • Apr 2012
                  • 9
                  i can, but ide rather just plug in lol...what prop u using on the cat? And thank you so much for your time.
                  • lenny
                    • Sep 2010
                    • 4296
                    Stock right now,
                    But the y535 may be a good one for the cat.
                    I will have to try running it on mine and see what it does.
                    ? ONLY IF THEY WORK
                    • steve513
                      • Apr 2012
                      • 9
                      where would i find that prop? Plasic or metal? And ill leave you alone lol thanx. You helpd out big time :)
                      • lenny
                        • Sep 2010
                        • 4296
                        It is metal.
                        Ose link,http://www.offshoreelectrics.com/categories.php?cat=16
                        Post a WTB,
                        Or look in swap shop, You may get lucky.
                        ? ONLY IF THEY WORK
                        • steve513
                          • Apr 2012
                          • 9
                          Lenny, Thank you very much, great info, now i must go do chores for the wife lol thank you for your time
