NQD jet boat up grade need help
  • Trexter67
    • Jul 2011
    • 11
    I am going to upgrade a nqd jet boat and I need a set up for under $50 exluding shipping I would like a motor between 3500-4000 kv. I need an ESC a motor and a battery and charger. Someone please help me out! I would like for it to be fast and powerful and mostly reliable.
  • Alexgar
    • Aug 2009
    • 3534
    What size boat and speed expectation also what batteries do you have might save ou a couple bux
    • Alexgar
      • Aug 2009
      • 3534
      Maybe 7l and 100 amp hobbyking esc
      • TheShaughnessy
        • 1431
        check out rcuniverse.com under the fast electric boat forums. lots of set ups for this boat over there.
        • Trexter67
          • Jul 2011
          • 11
          To Alexgar about an 18 in boat and I am new to hobbies like this why would I need such a large esc
          • Trexter67
            • Jul 2011
            • 11
            To TheShaughnessy thank you for the website I will check it out
            • C.B.R.
              • May 2011
              • 17
              I don't think you will be able to do it on $50 if you get new stuff.
              I used this motor http://www.hobbypartz.com/07e-c-sl-12t-2040-blue.html
              this ESC http://www.hobbypartz.com/07e-c-seaking-25a.html
              and bought a couple 1300 mah lipos and it was $60 without buying a charger.
              But these little jet boats are a blast to drive!
              Here's mine
              • C.B.R.
                • May 2011
                • 17
                Just noticed you are in TN, me too. Where at?
                • Trexter67
                  • Jul 2011
                  • 11
                  Memphis.I have been looking at hobby king and I found everything I need but the boat for $60. A 3800kv turnigy a 35a esc and a battery with charger. But thanks and cool video
                  • triumphjon
                    • Dec 2010
                    • 6
                    what modification have you made to the intake please ? im running the same jet unit in a custom built cathedral hull 012.jpg027.jpg028.jpgcurrently with the stock motor until i can afford a brushless one !
                    • Trexter67
                      • Jul 2011
                      • 11
                      I have not done anything yet. I have not even ordered any parts but if you want to see some videos on this jet out put just type NQD Jet Boat on YouTube. Sorry I could not help you any more than that
                      • C.B.R.
                        • May 2011
                        • 17
                        I did no modifications to the intake or pump. Only put a piece of metal screen over the intake to keep from sucking in rocks in shallow water. I also drilled a hole in the pump for pressurized cooling for the motor and esc.
                        • triumphjon
                          • Dec 2010
                          • 6
                          i shall need to put something over the intake as there is lots of blanket weed where i sail , which has already claimed my first prop ! where on the pump did you drill for a cooling inlet ?
                          • C.B.R.
                            • May 2011
                            • 17
                            I put it here....
                            in front of the nozzle so it doesn't block the nozzle movement.
                            • C.B.R.
                              • May 2011
                              • 17
                              here are more pictures
