NQD jet boat up grade need help
  • C.B.R.
    • May 2011
    • 17
    Trexter67, I am near Dickson,TN.
    • triumphjon
      • Dec 2010
      • 6
      whats the plate below the nozzle for ?
      • Trexter67
        • Jul 2011
        • 11
        How did you make the cover plate
        • C.B.R.
          • May 2011
          • 17
          It could be called a ride plate, I made it to keep from hitting the nozzle on rocks when creek bashing. I never ran the boat without it, so I really don't know if it helped the performance.
          • Trexter67
            • Jul 2011
            • 11
            How did you make it
            • C.B.R.
              • May 2011
              • 17
              Not sure what you mean by cover plate, unless you are talking about the ride plate. It is made from thick lexan. I used a sheet metal break to bend the lexan to match the shape of the hull. It is held on by the 4 pump screws. I'll get some pictures from the bottom tomorrow. Just got in from mowing the yard.
              • Trexter67
                • Jul 2011
                • 11
                Ok I did that earlier as well, 5 acres
                • sundog
                  Platinum Card Member
                  • Feb 2009
                  • 878
                  #23
                  Memphis.I have been looking at hobby king and I found everything I need but the boat for $60. A 3800kv turnigy a 35a esc and a battery with charger. But thanks and cool video
                  Trexter, that 3800kv motor is not your best choice. Ideally, you want a 3000kv (3S) or 4500kv (2S) tops, or it will sound faster but go no faster. I just did a conversion for a member on RCU and tested it yesterday, it has the 4800KV HK motor. The last 10-20% of throttle just make more noise, not more speed.
                  A ride plate will keep the hull from porpoising at full throttle with an oversized motor. I have a larger 3000kv outrunner in mine and it required the plate to keep it on the water. Very fast out of the hole.
                  Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
                  • Trexter67
                    • Jul 2011
                    • 11
                    #24
                    But will this motor work ok? It is an inrunner. I have already ordered the parts I want to know if I have messed up
                    • sundog
                      • Feb 2009
                      • 878
                      #25
                      Nope. I don't think you will be happy with it on either 2S or 3S. What battery are you going to be using?
                      • Trexter67
                        • Jul 2011
                        • 11
                        #26
                        1800mah 3s 20c
                        • Trexter67
                          • Jul 2011
                          • 11
                          #27
                          I have just found a turnigy 3000kv inrunner, 2623 is the size. Will that work?
                          • sundog
                            • Feb 2009
                            • 878
                            #28
                            If you have a water jacket for your motor you can use it with that battery - for a while anyway. Without a water jacket, it won't last long at all. Check battery temps often at first. You may experience the 'faster sound than speed' syndrome I spoke of before, or either it won't be able to attain top speed (not enough torque) and will heat up the battery significantly. If you decide on another motor, try to find something as close to 3000kv that you can. An outrunner that has a built-in fan will also do well in this boat. But that battery is borderline (36A). I usually recommend at least 2200mah and the highest 'C' rating you can afford. You really should read the Tear Into thread on RCU: http://www.rcuniverse.com/forum/m_7991409/tm.htm
                            • triumphjon
                              • Dec 2010
                              • 6
                              #29
                              hoping not to need trim tabs , but where did you source the mesh guard for the intake from ? im also looking into making my own metal prop !
                              • C.B.R.
                                • May 2011
                                • 17
                                #30
                                I haven't noticed that with mine, I have a 4800kv hobbywing (probably the same motor HobbyKing sells but from Hobbypartz.com). You can watch the video. That is how fast it goes on 2s, it is even faster on 3s. I have tried 4s, but would not recommend it to anyone!
