wire 5mm led
  • Smoothops
    It is never fast enough..
    • 128
    wire 5mm led
    Need help wiring some 5mm led lights for my boats and cars. Never tried and bought the leds but not sure how to wire or power them. Any help?
  • siberianhusky
    • Dec 2009
    • 2187
    Lots of info on the net about led wiring.
    • damfurst
      • 261
      Did these come with resistors or not?
      • Smoothops
        • 128
        No but after i watched a utube video i bought some 1.5 k Ohm what is the biggest size of battery? I have a 1000 mAh 7.4 volt 15c will that be too big?
        • Boaterguy
          • 1760
          depends, it will be much too big for one light, good for about 10 or more lights.
          • damfurst
            • 261
            Depending on whether I use a seperate battery (9 volt or 11.1v lipo), I've found that 100 ohm resistors are generally all that are required make the leds work. C doesn't really matter when dealing with led's either because their draw is so much less than a motor or servo for example. Sometimes I will use a seperate battery to power them and sometimes I'll power them from the vehicle(boat/car) battery through the receiver.
            • sailr
              • Nov 2007
              • 6927
              I have a small airplane all decked out with a gazillion leds. I use a separate 11.1V 800mah battery. Nothing in my setup regarding resistors. The leds are designed to run on 12V.
              Mini Cat Racing USA
              www.minicatracingusa.com
              • damfurst
                • 261
                Some led's are designed to work with 12v without any resistors. But if yours are supposed to be used with 3-4v then you will need a resistor otherwise they burn out very quickly like poof. Depending on what you are doing you can either wire them in parallel or series.
