15"Offshore Warrior mono further mods+ short run
  • SweetZ28
    • 1322
    I have one of the offshore woriers it's totally stock and on 3s it flys!
    I am waiting for the drive shaft to fail.... what is needed to put in a better unit?
    somebody sell a easy drop in replacement cable set up?
    THANKS
    WWW.PPRSLOTS.COM
    • Rich
      • Jan 2008
      • 551
      Originally posted by Dangergus
      I have 2 Gecko's and both running smooth. One has the stock drive line that I straightened out by raising up the prop to be level with the hull bottom then lowered the motor as much as possible. My 2nd, I changed to a .098 Octura flex and looks to be even smoother. I'm running Neu motors, 1105-3Y and orig on 9.6V Nimh's. On 2S they're a little slower so might bump up to the 2.5Y or 4.5D.
      Any recommendations for a good 2S motor? I really like the Neu's.
      The two you are considering would be good choices IMO.
      24 R/C vehicles and still counting...What budget?
      • Prop Nut
        • 11
        Hi Martin,
        I have 2 Offshore Warriors one stock and because of your post and vids on youtube I will mod the other one, similar to yours
        I would like to know what you think of this motor; http://www.hobbyking.com/hobbyking/s...idProduct=6387
        is it OK or to much? I just ordered the Overlander 2200 mah 3s 60c batteries thanks to You.
        Thank You for your time and help
        -D
        • martin
          • 2887
          You may find 4400kv on 3s to much on an outrunner,You will also find problems with the mount not clearing the collar on the motor shaft. When using 28mm diam outrunner as i do you have to really secure the lipo as its very close to the revolving body of the motor ecsecialy going with higher c lipos as their that much bigger in size & sit close to the motor. Dont try using stock esc with any upgrades . Martin.
          • Prop Nut
            • 11
            Thank You Martin
            Would you give a link to the motor that you use for a better reference for me? and if you wanted more speed (55 to 60 mph) what motor would you use? Thanks.
            -D
            • martin
              • 2887
              I am at the moment using a Mystery 2836-3800kv motor that i get from HK on Ebay. As for more speed motors are limited as to what you can get in the boat, Wait untill you try getting bigger motors in along with much larger esc & larger size lipos & youll realise how tight things are. Re going faster with the Warrior hull, Believe you me you will certainly need to strengthen the hull & hatch fitting in every area to withstand the impacts youll get. Ive practically destroyed the hull due to impacts & constant repairs. Martin.
              • Prop Nut
                • 11
                Thank You Martin for all your help and sharing all of the work you have done with your Offshore Warrior.
                I will give feedback as I get it.
                Your the BEST.
                -D
                • martin
                  • 2887
                  I would say once you start getting to mid 40s mph you will need to fit trim tabs, The boat runs much better with them as speeds increase. Also check the rear 3" of the hull bottom for any hook ( concave curve ) as this sticks the hull to the water if the bottom is not flat in this area & slows the boat. Just use a ruler or something straight sat on the hull to see if theirs a hollow & fill if nesessary to get it flat. Mine did have a hook & filled it. Martin.
                  • Dangergus
                    • Jun 2011
                    • 14
                    What do you suggest to fill and straighten the bottom of the hulls? I'm looking for something that's workable on these little hulls.
                    Thanks again for all the help.
                    • martin
                      • 2887
                      Auto body filler, Use the ones that are easy to sand & sand with a flat block of wood with the wet & dry wrapped around the block of wood so you get a nice flat surface & keep checking with a straight edge as you sand. If you still have slight hollows after sanding just put another layer of filler where needed & finish sanding. Martin.
                      • Rich
                        • Jan 2008
                        • 551
                        Do you think its a bit over kill?? Heck no!!!!! http://www.hobbypartz.com/96m31-car-2848-3900.html
                        • regatta
                          • Aug 2011
                          • 5
                          #27
                          Hi,
                          I am also looking to upgrade the drive line on the warrior.
                          I noticed you used the OSE mini strut and rudder kit (oct-oc4str-cda?). With this rudder, does it handle any differently from stock? How do you find this strut and rudder setup? Are you using the teflon liner?
                          I am going to stay with the stock motor for now, what props would be a good choice?
                          • Jeff Wohlt
                            • Jan 2008
                            • 2716
                            #28
                            You might want to try a 062 wire drive on those. What is the prop shaft size? I can also make smaller dia couplers for them.
                            www.rcraceboat.com
                            jwohlt5362@yahoo.com
                            • ashcossie
                              • Apr 2012
                              • 29
                              #29
                              will this be anygood for my warrior
                              • martin
                                • 2887
                                #30
                                When you fit an outrunner motor in the Warrior you have to make sure the battery is secured well as it is very close indeed to the spinning can of the motor. If the battery is allowed to move it will touch the can & ruin the battery by cutting into it.
